简介
As we all know, when supplying the short-circuited logic board with power, faulty components on it will get hot. For logic board bearing significant fever, we can locate the faulty component quickly and precisely with 'rosin smoking' method or freeze spray method. Today we are going to introduce a repair case for iPhone 7 won't turn on after water damage.
视频概述
Check the logic board carefully. The water damage indicator is red.
Areas around the WiFi module bear obvious signs of water damage.
Then, connect the two test leads of the Multimeter with DC Power Supply. Set voltage of the DC Power Supply to 3V. Get the black lead grounded. Meanwhile, get the red lead touched with Pin 1 of C2308.
Rosin on C3002 melts immediately. Judging by this, the short-circuited condition is caused by damage of C3002.
Also, for repair technicians, it’s important for you to understand how iPhone boot circuit works before starting your repair work.
- How to Fix iPhone 7 No Service
- How to Fix iPhone 7 Hey Siri Not Working
- iPhone 7 Plus Touch ID Not Working – Broken Home Button Cable Repair
- How to Fix iPhone 7 Rear Camera Keeps Shaking
- How to Fix iPhone 7 Plus Half Backlight
- How to Fix iPhone 7 Plus Won't Turn On After Water Damage
- iPhone 6 Won't Turn On - Water Damage Repair
- How to Fix Samsung S7 edge Won't Turn on - Logic Board Solution
另外一个人完成了本指南。
一条评论
Hi!
love this guide, I have this exact problem as I went swimming with it in the ocean.. I’ve swapped my logic board into another iphone 7 and it still wont turn on. I assume the sea water has maybe corroded the PCB somwhere. where can I start to confirm what needs to be replaced? is it hopeless or do I have a chance?
thanks
Alzoo
