简介
Malfunction of the backlight circuit can result in no backlight, half backlight, or won't turn on issues. For backlight issues commonly seen with iPhones, what's your solution? Hope our video today, the iPhone 7 Plus half backlight repair issue due to pseudo soldering of the display connector, will enlighten you on the subject.
视频概述
Check the logic board carefully. Nothing goes wrong.
Assemble the phone and test. The screen lights up and Apple logo appears. We can see with naked eyes that the right side of the screen is darker than the left side.
Judging by this, the fault might be related to the backlight circuit.
Open Refox. We can see that the voltage outputted from the backlight IC U4601 reaches Pin 45 of J4502 by way of C4602, FL4601 and C4605.
Continue to run diode mode measurement of C4602. The measured value is normal.
Judging by this, the abnormal value of Pin 45 is probably caused by open-circuited condition of its relevant circuit or malfunction of the display connector J4502.
Check J4502 carefully and we find that Pin 45 has been pseudo soldered.
- How to Fix iPhone 7 No Service
- How to Fix iPhone 7 Hey Siri Not Working
- iPhone 7 Plus Touch ID Not Working – Broken Home Button Cable Repair
- How to Fix iPhone 7 Rear Camera Keeps Shaking
- How to Fix iPhone 7 Plus Half Backlight
- How to Fix iPhone 7 Plus Won't Turn On After Water Damage
- iPhone 6 Won't Turn On - Water Damage Repair
- How to Fix Samsung S7 edge Won't Turn on - Logic Board Solution
