跳转到主内容
How to Fix an Xbox One Controller Stuck Button
你所需要的
  1. How to Fix an Xbox One Controller Stuck Button, How to Fix an Xbox One Controller Stuck Button: 步骤 1 中的图像 1,3 How to Fix an Xbox One Controller Stuck Button, How to Fix an Xbox One Controller Stuck Button: 步骤 1 中的图像 2,3 How to Fix an Xbox One Controller Stuck Button, How to Fix an Xbox One Controller Stuck Button: 步骤 1 中的图像 3,3
    • Use an opening tool to remove the back panels of the controller.
  2. How to Fix an Xbox One Controller Stuck Button: 步骤 2 中的图像 1,3 How to Fix an Xbox One Controller Stuck Button: 步骤 2 中的图像 2,3 How to Fix an Xbox One Controller Stuck Button: 步骤 2 中的图像 3,3
    • Remove the five screws from the back of the controller.
    • The 5th screw is behind the sticker in the battery compartment.
  3. How to Fix an Xbox One Controller Stuck Button: 步骤 3 中的图像 1,3 How to Fix an Xbox One Controller Stuck Button: 步骤 3 中的图像 2,3 How to Fix an Xbox One Controller Stuck Button: 步骤 3 中的图像 3,3
    • Remove the front and back covers.
    • Remove the screws on the inside.
  4. How to Fix an Xbox One Controller Stuck Button: 步骤 4 中的图像 1,3 How to Fix an Xbox One Controller Stuck Button: 步骤 4 中的图像 2,3 How to Fix an Xbox One Controller Stuck Button: 步骤 4 中的图像 3,3
    • Remove the screws.
    • Flip the controller over and remove the joysticks.
  5. How to Fix an Xbox One Controller Stuck Button: 步骤 5 中的图像 1,2 How to Fix an Xbox One Controller Stuck Button: 步骤 5 中的图像 2,2
    • Remove both screws near the trigger.
  6. How to Fix an Xbox One Controller Stuck Button: 步骤 6 中的图像 1,3 How to Fix an Xbox One Controller Stuck Button: 步骤 6 中的图像 2,3 How to Fix an Xbox One Controller Stuck Button: 步骤 6 中的图像 3,3
    • Remove the triggers to create more space.
    • Remove the screws holding the motherboard.
  7. How to Fix an Xbox One Controller Stuck Button: 步骤 7 中的图像 1,3 How to Fix an Xbox One Controller Stuck Button: 步骤 7 中的图像 2,3 How to Fix an Xbox One Controller Stuck Button: 步骤 7 中的图像 3,3
    • Remove the screws underneath the first chip board.
  8. How to Fix an Xbox One Controller Stuck Button: 步骤 8 中的图像 1,3 How to Fix an Xbox One Controller Stuck Button: 步骤 8 中的图像 2,3 How to Fix an Xbox One Controller Stuck Button: 步骤 8 中的图像 3,3
    • Remove all screws holding the motherboard.
    • Pry open the top of the controller to release the motherboard.
  9. How to Fix an Xbox One Controller Stuck Button: 步骤 9 中的图像 1,3 How to Fix an Xbox One Controller Stuck Button: 步骤 9 中的图像 2,3 How to Fix an Xbox One Controller Stuck Button: 步骤 9 中的图像 3,3
    • Remove the motherboard.
    • Remove the buttons.
  10. How to Fix an Xbox One Controller Stuck Button: 步骤 10 中的图像 1,3 How to Fix an Xbox One Controller Stuck Button: 步骤 10 中的图像 2,3 How to Fix an Xbox One Controller Stuck Button: 步骤 10 中的图像 3,3
    • Clean the new buttons with rubbing alcohol for less friction.
    • Clean the controller frame holes.
结论
另外一个人完成了本指南。
iAmChrisBro
于10/27/23注册
218 声望
撰写一个指南
团队
CSU Los Angeles, Team 4-17, Kershman Fall 2023 CSU Los Angeles, Team 4-17, Kershman Fall 2023 的会员
CSULA-KERSHMAN-F23S4G17
1 名成员
创作了1篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 7
过去 7 天: 62
过去 30 天: 229
总计 4,176
