简介
Use this guide to fix a non-retracting tape measure so that it retracts smoothly and on its own. The tape measure being fixed in this guide is the Ace 1in x 25ft Tape Rule. However, this guide should apply to any measuring tape needed. This guide requires a screwdriver to remove the screws depending on which kind of different screws tape measures may have. The purpose of this guide and why you should follow it is to make your tape measure retract smoother, faster and easier.
你所需要的
Grab your broken tape measure and inspect so that it doesn't retract.
When the whole tape is out, slowly begin rolling it back in.
Roll it back in keeping your thumb firmly pressed on the wheel so that it goes back in smoothly and won't come out.
Once you start reaching the end, keep the tape straight with your thumb so that it retracts with no inconveniences.
6等其他人完成本指南。
2指南评论
Heres the real solution for a tape that does not retract:
Disassemble until step 3
Roll out a bit of the tape
Roll it around the round thing with the spring in it once or twice (depends on how much retension you need) While holding the round thing in its position. Then reassemble. Done
