跳转到主内容
How to Fix an Unstable Ikea Poang Chair
你所需要的
  1. How to Fix an Unstable Ikea Poang Chair, How to Fix an Unstable Ikea Poang Chair: 步骤 1 中的图像 1,1
    • Start by removing the seat cushion from the frame.
  2. How to Fix an Unstable Ikea Poang Chair: 步骤 2 中的图像 1,3 How to Fix an Unstable Ikea Poang Chair: 步骤 2 中的图像 2,3 How to Fix an Unstable Ikea Poang Chair: 步骤 2 中的图像 3,3
    • Remove the upper bolt, which attaches the back of the seat to the armrests.
    • Remove the lower bolt, which is the upper bolt attaching the seat to the legs.
    • Remove the same bolts on the opposite side of the chair.
    • To loosen the bolts, turn the Allen wrench to the LEFT, as shown in the video.
  3. How to Fix an Unstable Ikea Poang Chair: 步骤 4 中的图像 1,1
    • Separate the back and seat of the chair from the legs and the armrest.
  4. How to Fix an Unstable Ikea Poang Chair: 步骤 5 中的图像 1,2 How to Fix an Unstable Ikea Poang Chair: 步骤 5 中的图像 2,2
    • Re-attach the bolts removed in Steps 2 and 3. Put each bolt into the correct location before tightening each bolt.
    • If the bolt attaching the seat tightens too easily, it is not in the hole and rests above or below the wood of the seat. This is what causes the tipping or dipping of the seat.
    • When attaching the bolt for the back of the chair, insert a plastic washer between the wood of the chair leg and the wood of the chair back. Without this washer, the two pieces will not sit flush. This allows the chair to shift and may cause the chair to become unstable.
    • For maximum stability, fully tighten all of the bolts in the chair.
    • As shown in the video, tighten by turning the Allen wrench to the RIGHT.
  5. How to Fix an Unstable Ikea Poang Chair: 步骤 7 中的图像 1,1
    • Set the chair cushion on the chair seat.
    • Secure the Velcro on the cushion to the Velcro on the chair back.
终点
3等其他人完成本指南。
Erik Romanski
于03/30/16注册
191 声望
撰写一个指南
团队
Michigan Tech, Team 1-21, Lauer Spring 2016 Michigan Tech, Team 1-21, Lauer Spring 2016 的会员
MTU-LAUER-S16S1G21
1 名成员
创作了2篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 7
过去 7 天: 28
过去 30 天: 118
总计 17,314
