跳转到主内容
How to Fix an Umbrella Rivet
你所需要的
  1. How to Fix an Umbrella Rivet, How to Fix an Umbrella Rivet: 步骤 1 中的图像 1,1
    • Open the umbrella into its proper position.
  2. How to Fix an Umbrella Rivet: 步骤 2 中的图像 1,1
    • Identify the broken stretcher that needs to be repaired.
  3. How to Fix an Umbrella Rivet: 步骤 3 中的图像 1,1
    • Close the umbrella halfway to release the tension in the stretchers.
    • This makes it easier to line up the holes in the next step.
  4. How to Fix an Umbrella Rivet: 步骤 4 中的图像 1,1
    • Take the two pieces of the broken stretcher and line up the rivet holes.
  5. How to Fix an Umbrella Rivet: 步骤 5 中的图像 1,1
    • Pass the 6" piece of wire through the rivet holes.
  6. How to Fix an Umbrella Rivet: 步骤 6 中的图像 1,1
    • Wrap the wire around the stretcher and thread it through the holes again.
    • Repeat until there is no more room to pass the wire through.
    • May need to use the pliers to get a better grip on the wire so it can be pulled tight.
  7. How to Fix an Umbrella Rivet: 步骤 7 中的图像 1,1
    • Tie two half-hitch knots with the wire.
    • If you do not know how to tie a half-hitch knot, follow the link provided at the beginning of the guide.
  8. How to Fix an Umbrella Rivet: 步骤 8 中的图像 1,1
    • Use the scissors to trim the two ends of the wire to about half an inch in length.
  9. How to Fix an Umbrella Rivet: 步骤 9 中的图像 1,1
    • Using the pliers, twist the ends of the wire together.
  10. How to Fix an Umbrella Rivet: 步骤 10 中的图像 1,1
    • Tuck the wires down and clamp with the pliers so the ends are not poking out.
终点
8等其他人完成本指南。
团队
Texas Tech, Team 3-8, Rauch SU 2016 Texas Tech, Team 3-8, Rauch SU 2016 的会员
TTU-RAUCH-SU16S3G8
2 名成员
创作了5篇指南
7指南评论
This is not called an ‘umbrella rivet replacement’.
SouthPark - 回复
I fixed my umbrella! Thank you. Umbrella is very old though, will see how much more time I can buy with this fix :)
Lou - 回复
The fix lasted about a month and a half and then the copper wire broke. I am trying the same technique but this time with a metal paper clip that I had. The paper clip is made of metal that's thicker than the copper wire. I only threaded it through one time and then twisted the ends. One paper clip was enough to fix 2 rivets (both the original one and a new one is now broken as well). I will try to report back if these also break.
Lou - 回复
6 months later and paperclip fix is still holding!
Lou -
Thanks! A paperclip worked!
Mayra L. -
添加评论
浏览统计数据:
过去 24 小时: 17
过去 7 天: 92
过去 30 天: 381
总计 31,308
