跳转到主内容
How to Fix an Overextending Holga 120N Camera Shutter
你所需要的
  1. How to Fix an Overextending Holga 120N Camera Shutter, How to Fix an Overextending Holga 120N Camera Shutter: 步骤 1 中的图像 1,2 How to Fix an Overextending Holga 120N Camera Shutter, How to Fix an Overextending Holga 120N Camera Shutter: 步骤 1 中的图像 2,2
    • Slide the two metal lanyard locks up and off the camera.
    • Pop the back of the camera off.
  2. How to Fix an Overextending Holga 120N Camera Shutter: 步骤 2 中的图像 1,2 How to Fix an Overextending Holga 120N Camera Shutter: 步骤 2 中的图像 2,2
    • Remove the screw above the opening to the shutter piece using a Phillips #00 screwdriver.
    • Remove the screw below the opening to the shutter piece using a Phillips #00 screwdriver.
  3. How to Fix an Overextending Holga 120N Camera Shutter: 步骤 3 中的图像 1,1
    • Pull the shutter piece out and away from the camera.
    • Pull the shutter piece away carefully to avoid snapping the wire.
  4. How to Fix an Overextending Holga 120N Camera Shutter: 步骤 4 中的图像 1,3 How to Fix an Overextending Holga 120N Camera Shutter: 步骤 4 中的图像 2,3 How to Fix an Overextending Holga 120N Camera Shutter: 步骤 4 中的图像 3,3
    • Cut off the spade terminal's right prong with scissors.
  5. How to Fix an Overextending Holga 120N Camera Shutter: 步骤 5 中的图像 1,1
    • Bend the spade terminal forward at a 90-degree angle.
  6. How to Fix an Overextending Holga 120N Camera Shutter: 步骤 6 中的图像 1,2 How to Fix an Overextending Holga 120N Camera Shutter: 步骤 6 中的图像 2,2
    • Slice the blue plastic off of the spade terminal with the boxcutter/Exacto-knife.
    • The plastic bottom is sealed on very tightly. Use caution when cutting it away!
    • Remove the plastic from the spade terminal.
  7. How to Fix an Overextending Holga 120N Camera Shutter: 步骤 7 中的图像 1,3 How to Fix an Overextending Holga 120N Camera Shutter: 步骤 7 中的图像 2,3 How to Fix an Overextending Holga 120N Camera Shutter: 步骤 7 中的图像 3,3
    • Place hot glue at the bottom of the spade terminal.
    • Place the spade terminal in the small hole underneath the shutter.
    • Point the spade terminal horizontally, facing the wire that leads back to the camera.
  8. How to Fix an Overextending Holga 120N Camera Shutter: 步骤 8 中的图像 1,1
    • Screw the shutter piece back into place using a Phillips #00 screwdriver.
  9. How to Fix an Overextending Holga 120N Camera Shutter: 步骤 9 中的图像 1,2 How to Fix an Overextending Holga 120N Camera Shutter: 步骤 9 中的图像 2,2
    • Return the back of the camera into place.
结论
You’ve now learned the following:
  • How to disassemble and reassemble a Holga 120N camera
  • How to add a spade terminal as a blocker
The spade terminal will stop the overextended shutter. Enjoy taking pictures!
Jacob DeLany
于09/28/21注册
169 声望
撰写一个指南
一条评论
That's a PZ1 bit which gets the screws out easily. If you got the screws out with a PH00 bit, either they changed the way the camera is made before mine was made or you are quite tenacious in your screwdriving.
s l - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 52
总计 1,366
