跳转到主内容
How to Fix an OXO Container's Jammed Button
你所需要的
  1. How to Fix an OXO Container's Jammed Button, How to Fix an OXO Container's Jammed Button: 步骤 1 中的图像 1,3 How to Fix an OXO Container's Jammed Button, How to Fix an OXO Container's Jammed Button: 步骤 1 中的图像 2,3 How to Fix an OXO Container's Jammed Button, How to Fix an OXO Container's Jammed Button: 步骤 1 中的图像 3,3
    • Hold the lid with the button facing down.
    • Twist the flat part in the direction of the arrows or counter clockwise.
  2. How to Fix an OXO Container's Jammed Button: 步骤 2 中的图像 1,3 How to Fix an OXO Container's Jammed Button: 步骤 2 中的图像 2,3 How to Fix an OXO Container's Jammed Button: 步骤 2 中的图像 3,3
    • Firmly pinch both the half-moon shaped openings.
    • Pull up the removed outer piece and set it aside.
  3. How to Fix an OXO Container's Jammed Button: 步骤 3 中的图像 1,1
    • Place the lid perpendicular and onto the top of the container's opening.
    • The button should pop out. Placing the lid on a flat surface will prevent them from coming out.
    • Locate the two holes.
  4. How to Fix an OXO Container's Jammed Button: 步骤 4 中的图像 1,2 How to Fix an OXO Container's Jammed Button: 步骤 4 中的图像 2,2
    • With a tool in each hand, insert them into the openings of the buttons.
    • Make sure the two tools are centered on the plastic in the openings.
    • Tools must be small enough to fit inside the openings - alternatives to spudgers work.
    • Firmly press downwards until the button pops out.
    • Applying a lot of pressure is necessary, but also may damage the plastic of the lid.
  5. How to Fix an OXO Container's Jammed Button: 步骤 5 中的图像 1,2 How to Fix an OXO Container's Jammed Button: 步骤 5 中的图像 2,2
    • Flip the lid so the button faces up.
    • It should be easy to pinch the sides of the button so that it pops up.
    • Pinch the two sides and gently pull up.
    • Remove the button.
  6. How to Fix an OXO Container's Jammed Button: 步骤 6 中的图像 1,3 How to Fix an OXO Container's Jammed Button: 步骤 6 中的图像 2,3 How to Fix an OXO Container's Jammed Button: 步骤 6 中的图像 3,3
    • Flip the button so the inside wire faces upwards.
    • Use pliers to bend the wire similar to its original shape.
    • Use the unbent wire as a reference to reshape the bent wire.
结论
To reassemble your device, squeeze the button back onto the lid and follow these instructions in reverse order.
Allen Wong
于02/03/23注册
133 声望
撰写一个指南
团队
UC Davis, Team 2-5, Andersen Winter 2023 UC Davis, Team 2-5, Andersen Winter 2023 的会员
UCD-ANDERSEN-W23S2G5
3 名成员
创作了1篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 23
过去 30 天: 121
总计 6,116
