跳转到主内容
How to Fix a broken Fan
你所需要的
  1. How to Fix a broken Fan, I am applying  Machine Oil to the Fan Rotor: 步骤 1 中的图像 1,2 How to Fix a broken Fan, I am applying  Machine Oil to the Fan Rotor: 步骤 1 中的图像 2,2
    • Take out the front metal grill.
    • By the side of the cover, there's a metal piece you have to flick open to get the front and back unlocked from each other.
  2. How to Fix a broken Fan: 步骤 2 中的图像 1,2 How to Fix a broken Fan: 步骤 2 中的图像 2,2
    • Turn the knob to take out the blade cap.
    • Spin the knob counterclockwise. This way, you are loosening the knob.
  3. How to Fix a broken Fan: 步骤 3 中的图像 1,2 How to Fix a broken Fan: 步骤 3 中的图像 2,2
    • Loosen the plastic nut on the rear grille in order to take the rear grille out.
  4. How to Fix a broken Fan: 步骤 4 中的图像 1,2 How to Fix a broken Fan: 步骤 4 中的图像 2,2
    • Unscrew the plastic on the fan motor, and gently pull the slide open: There are four screws, proceed to taking off the plastic plates.
  5. How to Fix a broken Fan: 步骤 5 中的图像 1,2 How to Fix a broken Fan: 步骤 5 中的图像 2,2
    • Apply machine oil onto the rusted parts.
    • Take the machine oil and make sure you apply the oil to the around fan rotor
    • Let the oil stay for about 5 minutes
    • Do not spill the oil on the surface or let the oil go into the rotor.
  6. How to Fix a broken Fan: 步骤 6 中的图像 1,2 How to Fix a broken Fan: 步骤 6 中的图像 2,2
    • Carefully place the plastic plate properly on the surface of the fan rotor.
    • Make sure the screws align with the holes on the fan motor, then proceed to screw.
  7. How to Fix a broken Fan: 步骤 7 中的图像 1,1
    • Place back the fan rear grill, pick up the plastic grill nut.
    • fit in the hole and screw down the fan rear grill upon the fan motor.
  8. How to Fix a broken Fan: 步骤 8 中的图像 1,1
    • Place the blade right back into the motor pin.
    • Take the blade, make sure the blade sit on the fan edges.
  9. How to Fix a broken Fan: 步骤 9 中的图像 1,1
    • Take the circlip, spin the circlip right on the blade, ensure it is tight.
  10. How to Fix a broken Fan: 步骤 10 中的图像 1,1
    • Pick up the front grille, ensure the grille aligns with the metal piece around the fan.
    • Then lock the metal piece, this way the front and the rear grilles are locked.
    • If the metal piece do not align, you would have issues locking the grilles to each other.
结论
2等其他人完成本指南。
TUOYO FABIYI
于09/08/23注册
238 声望
撰写一个指南
团队
York University, Team 2-8, O'Regan Fall 2023 York University, Team 2-8, O'Regan Fall 2023 的会员
YORK-O'REGAN-F23S2G8
1 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 8
过去 30 天: 42
总计 240
