跳转到主内容
How to Fix a Wobbly Leg on a Solid Wood Chair
你所需要的
  1. How to Fix a Wobbly Leg on a Solid Wood Chair, How to Fix a Wobbly Leg on a Solid Wood Chair: 步骤 1 中的图像 1,1
    • First, thoroughly assess your chair for loose elements.
    • Sit and jiggle them to test and note exactly what moves.
  2. How to Fix a Wobbly Leg on a Solid Wood Chair: 步骤 2 中的图像 1,3 How to Fix a Wobbly Leg on a Solid Wood Chair: 步骤 2 中的图像 2,3 How to Fix a Wobbly Leg on a Solid Wood Chair: 步骤 2 中的图像 3,3
    • Position an L-bracket as if it will brace the leg to the frame of the chair.
    • Mark the exact outline of the bracket, taking extra care when marking the center hole where your screws will hold the brace in place.
    • It might be beneficial to "x" the through the marked circles to approximate the exact center for the screw to enter.
  3. How to Fix a Wobbly Leg on a Solid Wood Chair: 步骤 3 中的图像 1,2 How to Fix a Wobbly Leg on a Solid Wood Chair: 步骤 3 中的图像 2,2
    • If possible, detach your chair legs.
    • In the case you cannot detach your chair legs, consider buying longer L-brackets so you still have enough room to hold your drill parallel to the chair surfaces.
  4. How to Fix a Wobbly Leg on a Solid Wood Chair: 步骤 4 中的图像 1,1
    • Check if the drill bit is longer than the width of the chair leg.
    • If so, consider marking the drill bit to your desired depth.
  5. How to Fix a Wobbly Leg on a Solid Wood Chair: 步骤 5 中的图像 1,3 How to Fix a Wobbly Leg on a Solid Wood Chair: 步骤 5 中的图像 2,3 How to Fix a Wobbly Leg on a Solid Wood Chair: 步骤 5 中的图像 3,3
    • Before drilling any holes, ensure that your drill bit is slightly smaller than the width of your screw. This will result in a more secure hold.
    • Pre-drill holes through the center of your marked circles on both your chair legs and chair frame.
  6. How to Fix a Wobbly Leg on a Solid Wood Chair: 步骤 6 中的图像 1,2 How to Fix a Wobbly Leg on a Solid Wood Chair: 步骤 6 中的图像 2,2
    • Using the drill, secure your L-brackets to the chair legs first.
    • Be sure to hold the drill and screw parallel to the drilling surface.
  7. How to Fix a Wobbly Leg on a Solid Wood Chair: 步骤 7 中的图像 1,1
    • For extra hold and durability, use a small amount of wood glue at the chair legs joints.
    • Be sure to wipe away any excess wood glue.
  8. How to Fix a Wobbly Leg on a Solid Wood Chair: 步骤 8 中的图像 1,2 How to Fix a Wobbly Leg on a Solid Wood Chair: 步骤 8 中的图像 2,2
    • Tighten any preexisting hardware holding the legs to the chair base before fixing the L-bracket to the chair.
  9. How to Fix a Wobbly Leg on a Solid Wood Chair: 步骤 9 中的图像 1,2 How to Fix a Wobbly Leg on a Solid Wood Chair: 步骤 9 中的图像 2,2
    • Finally, screw the second side of the L-bracket to the base of the chair.
结论
Reassemble any remaining loose pieces as they were disassembled unless otherwise noted.
2等其他人完成本指南。
Dhvani Thakkar
于04/28/17注册
175 声望
撰写一个指南
团队
UC Davis, Team S2-G6, Cole Spring 2017 UC Davis, Team S2-G6, Cole Spring 2017 的会员
UCD-COLE-S17S2G6
3 名成员
创作了1篇指南
一条评论
My entire corner wood pieces are broken and not fixable and the screen (bolt and nut) is bended also. I would like to purchase those small wood pieces, I am not a saavy. Need some help to find the pieces. you can mail me @ radhu_murali@hotmail.com.
Radhika Murali - 回复
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 88
过去 30 天: 347
总计 31,008
