跳转到主内容
How to Fix a Wobbling Y-Axis on a Creality Ender-3 Pro 3D Printer
你所需要的
  1. How to Fix a Wobbling Y-Axis on a Creality Ender-3 Pro 3D Printer, How to Fix a Wobbling Y-Axis on a Creality Ender-3 Pro 3D Printer: 步骤 1 中的图像 1,2 How to Fix a Wobbling Y-Axis on a Creality Ender-3 Pro 3D Printer, How to Fix a Wobbling Y-Axis on a Creality Ender-3 Pro 3D Printer: 步骤 1 中的图像 2,2
    • Unscrew the leveling wheels under the bed and remove the print bed from its brackets.
  2. How to Fix a Wobbling Y-Axis on a Creality Ender-3 Pro 3D Printer: 步骤 2 中的图像 1,1
    • Use the 6 mm open-end wrench to hold the bottom of the bolt connections that are not in contact with the railing, then loosen the bolts with a 3 mm hex key.
    • Do not remove the bolts, as this could move the bolt connection further from the railing.
  3. How to Fix a Wobbling Y-Axis on a Creality Ender-3 Pro 3D Printer: 步骤 3 中的图像 1,1
    • Orient the eccentric nut with the 10 mm open-end wrench, turning it until the wheel bearing is in contact with the rail.
  4. How to Fix a Wobbling Y-Axis on a Creality Ender-3 Pro 3D Printer: 步骤 4 中的图像 1,1
    • Hold the bottom of the loosened bolt-connection with the 6 mm open-end wrench, then refasten the bolt with a 3 mm hex key.
    • Do not overtighten the bolt connection as this could strip the screw head.
  5. How to Fix a Wobbling Y-Axis on a Creality Ender-3 Pro 3D Printer: 步骤 5 中的图像 1,1
    • Test the wheel bearing for slippage, using your fingers to attempt to turn the wheel bearing.
    • If slippage remains persistent, repeat steps 2-5 until the wheel bearing does not slip on the rail guide when tested.
  6. How to Fix a Wobbling Y-Axis on a Creality Ender-3 Pro 3D Printer: 步骤 6 中的图像 1,2 How to Fix a Wobbling Y-Axis on a Creality Ender-3 Pro 3D Printer: 步骤 6 中的图像 2,2
    • Place the print bed back over its bracket, refastening it with the leveling wheels.
结论
Your y-axis should now be secured without the worry of misprinted layers. Happy printing!
5等其他人完成本指南。
一条评论
Just want to say this is by far the most helpful of all how to articles I saw to address this issue. Thank you
John Harris - 回复
添加评论
浏览统计数据:
过去 24 小时: 8
过去 7 天: 66
过去 30 天: 365
总计 7,495
