跳转到主内容
How to Fix a Tunneling Candle
你所需要的
  1. How to Fix a Tunneling Candle, How to Fix a Tunneling Candle: 步骤 1 中的图像 1,3 How to Fix a Tunneling Candle, How to Fix a Tunneling Candle: 步骤 1 中的图像 2,3 How to Fix a Tunneling Candle, How to Fix a Tunneling Candle: 步骤 1 中的图像 3,3
    • Fill any kind of dish with hot water.
    • Add any brand of dish soap or hand soap to the water.
    • Mix the soap with water using a spoon.
  2. How to Fix a Tunneling Candle: 步骤 2 中的图像 1,2 How to Fix a Tunneling Candle: 步骤 2 中的图像 2,2
    • Place the candle inside the mix of water and soap.
    • Let the jar soak inside the pot.
    • Make sure the area on the jar that has a label is completely soaked.
    • After 5 to 10 minutes, remove the candle from the dish.
  3. How to Fix a Tunneling Candle: 步骤 3 中的图像 1,1
    • Use a sponge to wash and remove the label from the jar.
    • Removing the label helps you have a cleaner fix as it prevents the label from peeling off inside the boiling water and damaging your pot in future steps.
  4. How to Fix a Tunneling Candle: 步骤 4 中的图像 1,3 How to Fix a Tunneling Candle: 步骤 4 中的图像 2,3 How to Fix a Tunneling Candle: 步骤 4 中的图像 3,3
    • Fill another pot with water and place it on the stove.
    • Turn the stove to high heat.
    • Wait until the water is simmering.
  5. How to Fix a Tunneling Candle: 步骤 5 中的图像 1,3 How to Fix a Tunneling Candle: 步骤 5 中的图像 2,3 How to Fix a Tunneling Candle: 步骤 5 中的图像 3,3
    • Use oven mitts to place the candle inside the pot.
    • Wait 15 to 30 minutes for the wax to be fully melted.
  6. How to Fix a Tunneling Candle: 步骤 6 中的图像 1,3 How to Fix a Tunneling Candle: 步骤 6 中的图像 2,3 How to Fix a Tunneling Candle: 步骤 6 中的图像 3,3
    • While waiting for the wax to melt, grab two coffee stir sticks or similar objects, and tape them into a cross.
    • In this guide, I am using incense sticks.
  7. How to Fix a Tunneling Candle: 步骤 7 中的图像 1,3 How to Fix a Tunneling Candle: 步骤 7 中的图像 2,3 How to Fix a Tunneling Candle: 步骤 7 中的图像 3,3
    • Take the candle out of the pot using oven mitts.
    • Place the melted candle on a flat surface.
    • Remember to turn off the stove.
  8. How to Fix a Tunneling Candle: 步骤 8 中的图像 1,2 How to Fix a Tunneling Candle: 步骤 8 中的图像 2,2
    在这个步骤中使用的工具:
    • Use a pair of tweezers to grab and pull out the burnt wick of the candle.
    • Do not touch the hot wax with your fingers; use tweezers.
  9. How to Fix a Tunneling Candle: 步骤 9 中的图像 1,3 How to Fix a Tunneling Candle: 步骤 9 中的图像 2,3 How to Fix a Tunneling Candle: 步骤 9 中的图像 3,3
    • Place the cross that you made from the sticks on the edges of the candle jar.
    • Insert two new candle wicks inside the wax from the metal side.
    • Make sure the wicks are not close together.
    • Twist the wick around the sticks to prevent them from moving.
  10. How to Fix a Tunneling Candle: 步骤 10 中的图像 1,3 How to Fix a Tunneling Candle: 步骤 10 中的图像 2,3 How to Fix a Tunneling Candle: 步骤 10 中的图像 3,3
    • Wait for the wax to harden and remove the sticks.
    • Trim the candle wick to 1/4 inch.
    • You have fixed your tunneling candle.
终点
2等其他人完成本指南。
[deleted]
于01/18/21注册
245 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 12
总计 1,541
