跳转到主内容
How to Fix a Thrustmaster Eswap X Pro Controller Trigger
你所需要的
  1. How to Fix a Thrustmaster Eswap X Pro Controller Trigger, How to Fix a Thrustmaster Eswap X Pro Controller Trigger: 步骤 1 中的图像 1,2 How to Fix a Thrustmaster Eswap X Pro Controller Trigger, How to Fix a Thrustmaster Eswap X Pro Controller Trigger: 步骤 1 中的图像 2,2
    • Flip the controller so the backside is facing up.
    • Flip both of the switches away from the center.
  2. How to Fix a Thrustmaster Eswap X Pro Controller Trigger: 步骤 2 中的图像 1,3 How to Fix a Thrustmaster Eswap X Pro Controller Trigger: 步骤 2 中的图像 2,3 How to Fix a Thrustmaster Eswap X Pro Controller Trigger: 步骤 2 中的图像 3,3
    • Flip the controller over so the top is facing up.
    • Pull out both the joystick and the directional pad modules.
  3. How to Fix a Thrustmaster Eswap X Pro Controller Trigger: 步骤 3 中的图像 1,3 How to Fix a Thrustmaster Eswap X Pro Controller Trigger: 步骤 3 中的图像 2,3 How to Fix a Thrustmaster Eswap X Pro Controller Trigger: 步骤 3 中的图像 3,3
    • Flip the controller over again so the backside is facing up.
    • Use a spudger to remove five rubber screw covers.
  4. How to Fix a Thrustmaster Eswap X Pro Controller Trigger: 步骤 4 中的图像 1,3 How to Fix a Thrustmaster Eswap X Pro Controller Trigger: 步骤 4 中的图像 2,3 How to Fix a Thrustmaster Eswap X Pro Controller Trigger: 步骤 4 中的图像 3,3
    • Use a Phillips #1 screwdriver to remove each of the 4.0 mm exposed screws.
  5. How to Fix a Thrustmaster Eswap X Pro Controller Trigger: 步骤 5 中的图像 1,2 How to Fix a Thrustmaster Eswap X Pro Controller Trigger: 步骤 5 中的图像 2,2
    • Use a Phillips #1 screwdriver to loosen the captive screw and remove the trigger button.
  6. How to Fix a Thrustmaster Eswap X Pro Controller Trigger: 步骤 6 中的图像 1,3 How to Fix a Thrustmaster Eswap X Pro Controller Trigger: 步骤 6 中的图像 2,3 How to Fix a Thrustmaster Eswap X Pro Controller Trigger: 步骤 6 中的图像 3,3
    • Rotate the controller 90 degrees.
    • Pull off the magnetic side cover.
  7. How to Fix a Thrustmaster Eswap X Pro Controller Trigger: 步骤 7 中的图像 1,3 How to Fix a Thrustmaster Eswap X Pro Controller Trigger: 步骤 7 中的图像 2,3 How to Fix a Thrustmaster Eswap X Pro Controller Trigger: 步骤 7 中的图像 3,3
    • Lift the back cover slightly from where you removed the trigger button.
    • Use a Q-tip dipped with isopropyl alcohol to clean the surrounding area.
    • Additionally, wipe down the top face of the trigger with a Q-tip.
  8. How to Fix a Thrustmaster Eswap X Pro Controller Trigger: 步骤 8 中的图像 1,3 How to Fix a Thrustmaster Eswap X Pro Controller Trigger: 步骤 8 中的图像 2,3 How to Fix a Thrustmaster Eswap X Pro Controller Trigger: 步骤 8 中的图像 3,3
    • Reattach the trigger button onto the controller.
    • Use a Phillips #1 screwdriver to tighten the screw securing trigger button.
  9. How to Fix a Thrustmaster Eswap X Pro Controller Trigger: 步骤 9 中的图像 1,3 How to Fix a Thrustmaster Eswap X Pro Controller Trigger: 步骤 9 中的图像 2,3 How to Fix a Thrustmaster Eswap X Pro Controller Trigger: 步骤 9 中的图像 3,3
    • Use a Phillips #1 screwdriver to reattach the 4.0 mm screws to the back of the controller.
  10. How to Fix a Thrustmaster Eswap X Pro Controller Trigger: 步骤 10 中的图像 1,3 How to Fix a Thrustmaster Eswap X Pro Controller Trigger: 步骤 10 中的图像 2,3 How to Fix a Thrustmaster Eswap X Pro Controller Trigger: 步骤 10 中的图像 3,3
    • Notice that the notches on the rubber covers correspond with the notches on the screw hole.
    • Reattach the rubber covers above the screws.
  11. How to Fix a Thrustmaster Eswap X Pro Controller Trigger: 步骤 11 中的图像 1,1
    • Place the joystick and the directional pad modules back in their respective spots.
  12. How to Fix a Thrustmaster Eswap X Pro Controller Trigger: 步骤 12 中的图像 1,3 How to Fix a Thrustmaster Eswap X Pro Controller Trigger: 步骤 12 中的图像 2,3 How to Fix a Thrustmaster Eswap X Pro Controller Trigger: 步骤 12 中的图像 3,3
    • Reattach the magnetic side cover.
    • The controller is fixed!
结论
3等其他人完成本指南。
Laurence Chan
于01/26/23注册
268 声望
撰写一个指南
团队
UC Davis, Team 2-3, Morris Winter 2023 UC Davis, Team 2-3, Morris Winter 2023 的会员
UCD-MORRIS-W23S2G3
2 名成员
创作了1篇指南
3指南评论
The problem is it keeps happening after doing all these steps. is there any way or parts to replace the trigger sensor completely? Possibly with a nice hall effect sensor?
John Addington - 回复
You can remove the lever bar that goes from the screw to the sensor (the one you see on Step 7)
Spray a small amount of WD40 on the sensor and use a prong to rotate the part on its full range of motion several times, that will clean up the contact inside and it completely fixed the jitter on mine.
Alex L -
hi, i made an account here just to say this worked for me but on the thrustmaster eswap S pro controller, it's almost identical aside from the cover panels
Anna Fiore - 回复
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 40
过去 30 天: 125
总计 4,231
