跳转到主内容
How to Fix a Tear in a Jacket Lining
你所需要的
  1. How to Fix a Tear in a Jacket Lining, How to Fix a Tear in a Jacket Lining: 步骤 1 中的图像 1,3 How to Fix a Tear in a Jacket Lining, How to Fix a Tear in a Jacket Lining: 步骤 1 中的图像 2,3 How to Fix a Tear in a Jacket Lining, How to Fix a Tear in a Jacket Lining: 步骤 1 中的图像 3,3
    • Turn the jacket inside out.
  2. How to Fix a Tear in a Jacket Lining: 步骤 2 中的图像 1,2 How to Fix a Tear in a Jacket Lining: 步骤 2 中的图像 2,2
    • Put the thread through the needle hole.
    • Use thread that is the same color as the material you are sewing.
  3. How to Fix a Tear in a Jacket Lining: 步骤 3 中的图像 1,3 How to Fix a Tear in a Jacket Lining: 步骤 3 中的图像 2,3 How to Fix a Tear in a Jacket Lining: 步骤 3 中的图像 3,3
    • Take the two ends of the thread and knot them together.
  4. How to Fix a Tear in a Jacket Lining: 步骤 4 中的图像 1,2 How to Fix a Tear in a Jacket Lining: 步骤 4 中的图像 2,2
    • Cut the excess thread off.
  5. How to Fix a Tear in a Jacket Lining: 步骤 5 中的图像 1,3 How to Fix a Tear in a Jacket Lining: 步骤 5 中的图像 2,3 How to Fix a Tear in a Jacket Lining: 步骤 5 中的图像 3,3
    • Push the needle through the fabric and pull it between the two threads to create a knot.
    • This prevents the thread from sliding through the fabric as you are sewing.
  6. How to Fix a Tear in a Jacket Lining: 步骤 6 中的图像 1,3 How to Fix a Tear in a Jacket Lining: 步骤 6 中的图像 2,3 How to Fix a Tear in a Jacket Lining: 步骤 6 中的图像 3,3
    • Place one stitch on one side then place another one on the other side of the fabric.
    • Make sure the stitches are parallel and evenly distributed or the seams will not look straight.
    • Repeat this process until you have stitched down the length of the tear.
  7. How to Fix a Tear in a Jacket Lining: 步骤 7 中的图像 1,2 How to Fix a Tear in a Jacket Lining: 步骤 7 中的图像 2,2
    • Pull the thread through.
  8. How to Fix a Tear in a Jacket Lining: 步骤 8 中的图像 1,3 How to Fix a Tear in a Jacket Lining: 步骤 8 中的图像 2,3 How to Fix a Tear in a Jacket Lining: 步骤 8 中的图像 3,3
    • Close the stitch.
  9. How to Fix a Tear in a Jacket Lining: 步骤 9 中的图像 1,2 How to Fix a Tear in a Jacket Lining: 步骤 9 中的图像 2,2
    • Cut off the excess thread off after securing the stitch.
  10. How to Fix a Tear in a Jacket Lining: 步骤 10 中的图像 1,2 How to Fix a Tear in a Jacket Lining: 步骤 10 中的图像 2,2
    • This is the final product.
结论
If you mess up on a stitch, you can always cut and pull it out and start all over again.
4等其他人完成本指南。
Electra Pyatt
于03/22/21注册
253 声望
撰写一个指南
团队
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 30
过去 30 天: 117
总计 8,019
