跳转到主内容
How to Fix a Sweater Snag
你所需要的
  1. How to Fix a Sweater Snag, How to Fix a Sweater Snag: 步骤 1 中的图像 1,2 How to Fix a Sweater Snag, How to Fix a Sweater Snag: 步骤 1 中的图像 2,2
    • Using scissors, cut thread that matches the color of your sweater.
  2. How to Fix a Sweater Snag: 步骤 2 中的图像 1,2 How to Fix a Sweater Snag: 步骤 2 中的图像 2,2
    • Pull thread through the needle and tie a knot at the end of the needle.
  3. How to Fix a Sweater Snag: 步骤 3 中的图像 1,1
    • Lay your sweater out on a smooth surface.
  4. How to Fix a Sweater Snag: 步骤 4 中的图像 1,1
    • Identify the snag from the inside of your sweater.
  5. How to Fix a Sweater Snag: 步骤 5 中的图像 1,2 How to Fix a Sweater Snag: 步骤 5 中的图像 2,2
    • Pull the needle through the sweater at the site of the snag, ensuring that the needle is facing the inside of the sweater.
    • Ensure that you have enough thread to work with.
  6. How to Fix a Sweater Snag: 步骤 6 中的图像 1,2 How to Fix a Sweater Snag: 步骤 6 中的图像 2,2
    • Loop the snag around the needle.
    • Begin to pull the needle through the snag to the other side.
  7. How to Fix a Sweater Snag: 步骤 7 中的图像 1,2 How to Fix a Sweater Snag: 步骤 7 中的图像 2,2
    • Once again, face the needle towards the inside of the sweater then pull the needle through the site of snag.
  8. How to Fix a Sweater Snag: 步骤 8 中的图像 1,2 How to Fix a Sweater Snag: 步骤 8 中的图像 2,2
    • Cut the loose thread.
    • Make sure there is enough thread sticking out from where the snag was.
  9. How to Fix a Sweater Snag: 步骤 9 中的图像 1,1
    • Identify the site of the snag to ensure steps were followed correctly.
  10. How to Fix a Sweater Snag: 步骤 10 中的图像 1,1
    • Steam the sweater at the site of the snag to secure the fix in place.
结论
Hannah Ziebell
于02/20/24注册
181 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 9
过去 7 天: 68
过去 30 天: 250
总计 1,619
