跳转到主内容
How to Fix a Stretched or Loose Canvas
你所需要的
  1. How to Fix a Stretched or Loose Canvas, How to Fix a Stretched or Loose Canvas: 步骤 1 中的图像 1,2 How to Fix a Stretched or Loose Canvas, How to Fix a Stretched or Loose Canvas: 步骤 1 中的图像 2,2
    • Fill a spray bottle with water at room temperature.
    • In case that you do not have a spray bottle you can use a dishcloth and moisten it.
  2. How to Fix a Stretched or Loose Canvas: 步骤 2 中的图像 1,3 How to Fix a Stretched or Loose Canvas: 步骤 2 中的图像 2,3 How to Fix a Stretched or Loose Canvas: 步骤 2 中的图像 3,3
    • Close the spray bottle tightly.
    • Turn the nozzle to spray.
  3. How to Fix a Stretched or Loose Canvas: 步骤 3 中的图像 1,2 How to Fix a Stretched or Loose Canvas: 步骤 3 中的图像 2,2
    • Put a towel on a flat surface and lay the canvas face down on the towel.
  4. How to Fix a Stretched or Loose Canvas: 步骤 4 中的图像 1,3 How to Fix a Stretched or Loose Canvas: 步骤 4 中的图像 2,3 How to Fix a Stretched or Loose Canvas: 步骤 4 中的图像 3,3
    • Carefully wet the entire backside of the canvas with the spray, or press water onto the canvas with the dishcloth.
    • Only spray until it is damp. Do not soak the canvas.
    • It does not matter if the canvas is new, old, has unfinished artwork or it is completed.
  5. How to Fix a Stretched or Loose Canvas: 步骤 5 中的图像 1,2 How to Fix a Stretched or Loose Canvas: 步骤 5 中的图像 2,2
    • Turn on the dryer so warm air comes out.
  6. How to Fix a Stretched or Loose Canvas: 步骤 6 中的图像 1,3 How to Fix a Stretched or Loose Canvas: 步骤 6 中的图像 2,3 How to Fix a Stretched or Loose Canvas: 步骤 6 中的图像 3,3
    • Blow dry the canvas with a hair dryer on warm until it's completely dry.
    • Keep the hair dryer at least 3 to 5 inches away from the canvas.
    • Do not place the hair dryer directly on the canvas. The heat from the hair dryer can burn the canvas.
  7. How to Fix a Stretched or Loose Canvas: 步骤 7 中的图像 1,2 How to Fix a Stretched or Loose Canvas: 步骤 7 中的图像 2,2
    • Flip the canvas over and check that it is to your liking.
    • Flip the canvas again and double check.
    • Repeat the process again if the canvas is not completely fixed.
结论
If it does not work, you should follow another guide where plaster is used in the canvas.
另外一个人完成了本指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 38
总计 2,495
