跳转到主内容
How to Fix a Squeaky Door Hinge
你所需要的
  1. How to Fix a Squeaky Door Hinge, How to Fix a Squeaky Door Hinge: 步骤 1 中的图像 1,1
    • Insert the end of the flathead screwdriver into the crease between the top of the pin and the hinge.
  2. How to Fix a Squeaky Door Hinge: 步骤 2 中的图像 1,1
    • Take the hammer and hit the handle end of the screwdriver until the pin can be pulled out. This may take a while depending on the door.
  3. How to Fix a Squeaky Door Hinge: 步骤 3 中的图像 1,1
    • Place the pin in a bowl of mineral oil (or other household lubricant) and let it rest.
  4. How to Fix a Squeaky Door Hinge: 步骤 4 中的图像 1,1
    • Use a brush to apply oil to the empty hinge.
  5. How to Fix a Squeaky Door Hinge: 步骤 5 中的图像 1,1
    • Take the pin from the bowl and reinsert it into the door hinge, using a hammer if necessary.
    • Open and close the door a few times. This will help the oil to seep into the cracks of the hinge.
  6. How to Fix a Squeaky Door Hinge: 步骤 7 中的图像 1,1
    • Use a towel to catch any drips of oil and to wipe off the hinge.
结论
The door should now be quite silent when opening and closing. Thank you for reading.
3等其他人完成本指南。
Jake Herson
于03/30/16注册
219 声望
撰写一个指南
团队
Michigan Tech, Team 1-10, Lauer Spring 2016 Michigan Tech, Team 1-10, Lauer Spring 2016 的会员
MTU-LAUER-S16S1G10
1 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 18
过去 30 天: 81
总计 5,312
