跳转到主内容
How to Fix a Squeaky Brother SC 9500 Computerized Sewing Machine
你所需要的
  1. How to Fix a Squeaky Brother SC 9500 Computerized Sewing Machine, How to Fix a Squeaky Brother SC 9500 Computerized Sewing Machine: 步骤 1 中的图像 1,1
    • Flip the power switch on the back end of the sewing machine to "off."
    • For extra security, also unplug the power cord entirely.
  2. How to Fix a Squeaky Brother SC 9500 Computerized Sewing Machine: 步骤 2 中的图像 1,2 How to Fix a Squeaky Brother SC 9500 Computerized Sewing Machine: 步骤 2 中的图像 2,2
    • Remove any thread spools from the machine and set aside.
    • You don't want any thread in the machine while cleaning it.
  3. How to Fix a Squeaky Brother SC 9500 Computerized Sewing Machine: 步骤 3 中的图像 1,3 How to Fix a Squeaky Brother SC 9500 Computerized Sewing Machine: 步骤 3 中的图像 2,3 How to Fix a Squeaky Brother SC 9500 Computerized Sewing Machine: 步骤 3 中的图像 3,3
    • Slide the bobbin plate lock switch to the right.
    • The plate cover will pop open.
    • Remove the plate cover.
    • Remove the bobbin (if you have one loaded).
  4. How to Fix a Squeaky Brother SC 9500 Computerized Sewing Machine: 步骤 4 中的图像 1,3 How to Fix a Squeaky Brother SC 9500 Computerized Sewing Machine: 步骤 4 中的图像 2,3 How to Fix a Squeaky Brother SC 9500 Computerized Sewing Machine: 步骤 4 中的图像 3,3
    • Locate the presser foot release switch on the back of the presser foot.
    • Squeeze the release switch gently.
    • The pressure foot will drop away. Set it aside for later.
  5. How to Fix a Squeaky Brother SC 9500 Computerized Sewing Machine: 步骤 5 中的图像 1,2 How to Fix a Squeaky Brother SC 9500 Computerized Sewing Machine: 步骤 5 中的图像 2,2
    • Use a coin to twist the needle securing screw towards yourself (counterclockwise).
    • The needle will drop down when it's loose enough. Carefully set the needle aside.
  6. How to Fix a Squeaky Brother SC 9500 Computerized Sewing Machine: 步骤 6 中的图像 1,3 How to Fix a Squeaky Brother SC 9500 Computerized Sewing Machine: 步骤 6 中的图像 2,3 How to Fix a Squeaky Brother SC 9500 Computerized Sewing Machine: 步骤 6 中的图像 3,3
    • Use a coin to unscrew the two screws holding the bobbin well cover plate in place.
    • The first screw is located in the middle of the grid lines on the metal plate. The second screw is located in the top right corner of the metal plate.
    • Lift the well cover plate from the left edge first to remove it.
  7. How to Fix a Squeaky Brother SC 9500 Computerized Sewing Machine: 步骤 7 中的图像 1,3 How to Fix a Squeaky Brother SC 9500 Computerized Sewing Machine: 步骤 7 中的图像 2,3 How to Fix a Squeaky Brother SC 9500 Computerized Sewing Machine: 步骤 7 中的图像 3,3
    • Pinch the black bobbin well and lift it up and away from the bobbin well tray to remove it.
    • Do not rotate the bobbin well when you remove it (maintain the same orientation). This makes it easier to replace the well at the end.
  8. How to Fix a Squeaky Brother SC 9500 Computerized Sewing Machine: 步骤 8 中的图像 1,2 How to Fix a Squeaky Brother SC 9500 Computerized Sewing Machine: 步骤 8 中的图像 2,2
    • Use a straw cleaner to remove dust and lint from the bobbin well tray.
    • You should also use the straw cleaner to clean between the metal teeth on the feed dogs.
  9. How to Fix a Squeaky Brother SC 9500 Computerized Sewing Machine: 步骤 9 中的图像 1,2 How to Fix a Squeaky Brother SC 9500 Computerized Sewing Machine: 步骤 9 中的图像 2,2
    • Replace the bobbin well once all the dust is gone.
    • Make sure the black tab on the black bobbin well is placed right up against the metal spring in the bobbin well tray.
    • If it's not aligned properly, your machine will not work. When you twist the black bobbin well counterclockwise, the plastic tab should depress the metal spring.
  10. How to Fix a Squeaky Brother SC 9500 Computerized Sewing Machine: 步骤 10 中的图像 1,3 How to Fix a Squeaky Brother SC 9500 Computerized Sewing Machine: 步骤 10 中的图像 2,3 How to Fix a Squeaky Brother SC 9500 Computerized Sewing Machine: 步骤 10 中的图像 3,3
    • Replace the bobbin well plate cover and the two screws.
  11. How to Fix a Squeaky Brother SC 9500 Computerized Sewing Machine: 步骤 11 中的图像 1,3 How to Fix a Squeaky Brother SC 9500 Computerized Sewing Machine: 步骤 11 中的图像 2,3 How to Fix a Squeaky Brother SC 9500 Computerized Sewing Machine: 步骤 11 中的图像 3,3
    • Turn the machine around to the back and unscrew the single screw on the far right edge.
    • The faceplate screw is set about an inch into the plastic body of the machine.
    • Pinch the bottom edge of the faceplate and pull up to detach.
  12. How to Fix a Squeaky Brother SC 9500 Computerized Sewing Machine: 步骤 12 中的图像 1,3 How to Fix a Squeaky Brother SC 9500 Computerized Sewing Machine: 步骤 12 中的图像 2,3 How to Fix a Squeaky Brother SC 9500 Computerized Sewing Machine: 步骤 12 中的图像 3,3
    • Use the straw cleaner to dust the top, bottom left, and inner right sides of the internal needle arm mechanism.
  13. How to Fix a Squeaky Brother SC 9500 Computerized Sewing Machine: 步骤 13 中的图像 1,3 How to Fix a Squeaky Brother SC 9500 Computerized Sewing Machine: 步骤 13 中的图像 2,3 How to Fix a Squeaky Brother SC 9500 Computerized Sewing Machine: 步骤 13 中的图像 3,3
    • Locate the inner joint. It looks like a large round disk in the right side of the needle arm mechanism.
    • A flashlight is helpful to locate the joint.
    • Apply two drops of sewing machine oil to this joint.
  14. How to Fix a Squeaky Brother SC 9500 Computerized Sewing Machine: 步骤 14 中的图像 1,1
    • Turn the hand wheel on the end of your machine two full times clockwise to spread the oil around the joint.
  15. How to Fix a Squeaky Brother SC 9500 Computerized Sewing Machine: 步骤 15 中的图像 1,2 How to Fix a Squeaky Brother SC 9500 Computerized Sewing Machine: 步骤 15 中的图像 2,2
    • Replace the faceplate.
    • Slot the top edge over the exposed inner mechanism first.
    • Lower the faceplate cover until it snaps into place at the bottom.
    • Replace the screw of the back of the machine until it is hand-tight.
  16. How to Fix a Squeaky Brother SC 9500 Computerized Sewing Machine: 步骤 16 中的图像 1,3 How to Fix a Squeaky Brother SC 9500 Computerized Sewing Machine: 步骤 16 中的图像 2,3 How to Fix a Squeaky Brother SC 9500 Computerized Sewing Machine: 步骤 16 中的图像 3,3
    • Align the presser foot bar with the presser foot clip.
    • Pull down on the presser foot lever to push the clip into the bar. It will audibly snap into place.
    • Push the presser foot lever up to check that the presser foot is secure.
  17. How to Fix a Squeaky Brother SC 9500 Computerized Sewing Machine: 步骤 17 中的图像 1,2 How to Fix a Squeaky Brother SC 9500 Computerized Sewing Machine: 步骤 17 中的图像 2,2
    • Lastly, carefully replace the needle.
    • Sewing machine needles have a round front and a flat back. Insert the needle with the flat back facing away from you.
    • Use a coin to tighten the needle screw clockwise until it is hand-tight.
结论
Congratulations! Your sewing machine is ready to be re-threaded and used. Enjoy sewing squeak-free.
另外一个人完成了本指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 46
总计 588
