跳转到主内容
加入维修社区 - 创建账户
How to Fix a Squeaky Bed Frame
你所需要的
    1. How to Fix a Squeaky Bed Frame, How to Fix a Squeaky Bed Frame: 步骤 1 中的图像 1,1
      • Remove anything that is on the bed frame.
      询问修复机器人
      添加评论
    2. How to Fix a Squeaky Bed Frame: 步骤 2 中的图像 1,1
      • Shake the bed frame to pinpoint the area of noise.
      询问修复机器人
      添加评论
    3. How to Fix a Squeaky Bed Frame: 步骤 3 中的图像 1,1
      • Identify which type of screw the bedframe uses in the given area.
      • You will need to make use of the corresponding screwdriver throughout the guide.
      • Typically, the bed frame will use the same type of screws throughout.
      询问修复机器人
      添加评论
    4. How to Fix a Squeaky Bed Frame: 步骤 4 中的图像 1,1
      • Ensure the components of the bed frame are aligned.
      • Identify gaps between parts of the frame.
      • Tighten the screws where gaps are present
      • Sometimes mismatched components cause squeakiness.
      询问修复机器人
      添加评论
    5. How to Fix a Squeaky Bed Frame: 步骤 5 中的图像 1,1
      • Tighten the screws within the area of noise.
      • It is recommended to retighten all the screws to avoid any future squeakiness but it is not required.
      询问修复机器人
      添加评论
    6. How to Fix a Squeaky Bed Frame: 步骤 6 中的图像 1,1
      • Spray WD-40 into all the contact points of the bed frame.
      • This includes screws and intersections of the frame.
      • Be careful of the spray around children and your eyes.
      询问修复机器人
      添加评论
    7. How to Fix a Squeaky Bed Frame: 步骤 7 中的图像 1,1
      • This is an alternative for the previous step.
      • If WD-40 is not available, using a q-tip dipped in a vegetable oil (or a comparable oil that is available) can be used to lubricate the contact points.
      询问修复机器人
      添加评论
结论
Reassemble the bed to your liking.
取消:我没有完成这个指南。
另外一个人完成了本指南。
Jennifer Nguyen
于01/20/21注册
160 声望
撰写一个指南
团队
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 20
过去 30 天: 101
总计 3,758
