跳转到主内容
How to Fix a Small Hole in a Sock
你所需要的
  1. How to Fix a Small Hole in a Sock, How to Fix a Small Hole in a Sock: 步骤 1 中的图像 1,3 How to Fix a Small Hole in a Sock, How to Fix a Small Hole in a Sock: 步骤 1 中的图像 2,3 How to Fix a Small Hole in a Sock, How to Fix a Small Hole in a Sock: 步骤 1 中的图像 3,3
    • Place one end of your thread through the hole of the needle.
    • Wet the end of your thread to make it easier to go through the hole.
    • Pull your thread all the way through and match the ends of the thread together.
    • Tie a knot with the ends of your thread.
    • The needle is sharp. Handle it carefully to prevent poking your fingers or hand.
  2. How to Fix a Small Hole in a Sock: 步骤 2 中的图像 1,2 How to Fix a Small Hole in a Sock: 步骤 2 中的图像 2,2
    • Insert your tennis ball into the sock until it is lined up with the hole in your sock.
  3. How to Fix a Small Hole in a Sock: 步骤 3 中的图像 1,3 How to Fix a Small Hole in a Sock: 步骤 3 中的图像 2,3 How to Fix a Small Hole in a Sock: 步骤 3 中的图像 3,3
    • Insert your needle into the inside of the sock at the edge of the hole no more than half a centimeter away from the edge.
    • Pull the needle all the way through.
    • If the tail of your thread is too long, trim the excess.
  4. How to Fix a Small Hole in a Sock: 步骤 4 中的图像 1,1
    • Insert your needle next to and below where the first insert was.
    • Pull your needle all the way through to create your first stitch.
  5. How to Fix a Small Hole in a Sock: 步骤 5 中的图像 1,2 How to Fix a Small Hole in a Sock: 步骤 5 中的图像 2,2
    • Insert your needle in the opposite side of the hole and pull to create another stitch.
    • Repeat this step, crisscrossing your stitches until you reach the end of the hole.
    • Keep your stitches loose. You will tighten them at the end.
  6. How to Fix a Small Hole in a Sock: 步骤 6 中的图像 1,3 How to Fix a Small Hole in a Sock: 步骤 6 中的图像 2,3 How to Fix a Small Hole in a Sock: 步骤 6 中的图像 3,3
    • Once you reach the end of the hole, carefully pull on your thread to tighten the stitches together.
  7. How to Fix a Small Hole in a Sock: 步骤 7 中的图像 1,2 How to Fix a Small Hole in a Sock: 步骤 7 中的图像 2,2
    • To close off the stitch, insert your needle back under all of your stitches and pull out your needle at the top of the repair.
    • Pull your needle through, but not all the way, to create a small loop.
  8. How to Fix a Small Hole in a Sock: 步骤 8 中的图像 1,2 How to Fix a Small Hole in a Sock: 步骤 8 中的图像 2,2
    • Insert the needle through the small loop.
    • Pull your needle until the loop disappears.
  9. How to Fix a Small Hole in a Sock: 步骤 9 中的图像 1,2 How to Fix a Small Hole in a Sock: 步骤 9 中的图像 2,2
    • To create a final stitch, insert your needle back under all of your stitches.
    • Pull the thread all the way through.
  10. How to Fix a Small Hole in a Sock: 步骤 10 中的图像 1,3 How to Fix a Small Hole in a Sock: 步骤 10 中的图像 2,3 How to Fix a Small Hole in a Sock: 步骤 10 中的图像 3,3
    • Trim off the excess thread.
    • Remove the tennis ball from your sock.
终点
4等其他人完成本指南。
Yuchen Xu
于02/03/23注册
232 声望
撰写一个指南
团队
UC Davis, Team 3-2, Andersen Winter 2023 UC Davis, Team 3-2, Andersen Winter 2023 的会员
UCD-ANDERSEN-W23S3G2
3 名成员
创作了3篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 9
过去 7 天: 45
过去 30 天: 175
总计 2,519
