跳转到主内容
How to Fix a Slipping Violin Peg
你所需要的
  1. How to Fix a Slipping Violin Peg, How to Fix a Slipping Violin Peg: 步骤 1 中的图像 1,3 How to Fix a Slipping Violin Peg, How to Fix a Slipping Violin Peg: 步骤 1 中的图像 2,3 How to Fix a Slipping Violin Peg, How to Fix a Slipping Violin Peg: 步骤 1 中的图像 3,3
    • Completely unwind the string affected by the loose peg.
    • Turn the peg clockwise for strings G and D and counterclockwise for strings A and E.
  2. How to Fix a Slipping Violin Peg: 步骤 2 中的图像 1,1
    • Slide the peg out towards you to remove it from the pegbox.
    • The pegbox contains the holes that the pegs go into.
  3. How to Fix a Slipping Violin Peg: 步骤 3 中的图像 1,2 How to Fix a Slipping Violin Peg: 步骤 3 中的图像 2,2
    • Locate the points on the peg that come into contact with the pegbox.
    • Rub the peg compound all the way around the peg on the points that contact the pegbox.
  4. How to Fix a Slipping Violin Peg: 步骤 4 中的图像 1,3 How to Fix a Slipping Violin Peg: 步骤 4 中的图像 2,3 How to Fix a Slipping Violin Peg: 步骤 4 中的图像 3,3
    • Reinsert the peg by pushing inwards.
    • Turn the peg counterclockwise or clockwise to evenly distribute the compound.
  5. How to Fix a Slipping Violin Peg: 步骤 5 中的图像 1,2 How to Fix a Slipping Violin Peg: 步骤 5 中的图像 2,2
    • Wipe away the excess compound that is outside of the pegbox with a cloth or paper towel.
  6. How to Fix a Slipping Violin Peg: 步骤 6 中的图像 1,3 How to Fix a Slipping Violin Peg: 步骤 6 中的图像 2,3 How to Fix a Slipping Violin Peg: 步骤 6 中的图像 3,3
    • Locate the hole on the peg and insert the string through it.
    • Tightly angle the string away from the peg head with one hand, while turning the peg toward the scroll with the other hand.
    • The scroll is the woodcarving at the top of the violin.
    • After one or two turns, angle the string toward the peg head (vertical alignment).
  7. How to Fix a Slipping Violin Peg: 步骤 7 中的图像 1,2 How to Fix a Slipping Violin Peg: 步骤 7 中的图像 2,2
    • Tune the string.
    • For strings A and E, tightly turn the peg clockwise, and for strings G and D, turn the peg counterclockwise.
结论
To reassemble your device, follow these instructions in reverse order. Be advised that steps 5 and 7 are optional.
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 53
总计 411
