跳转到主内容
How to Fix a Skewed Wheel on a Children's Kick Scooter
你所需要的
  1. How to Fix a Skewed Wheel on a Children's Kick Scooter, How to Fix a Skewed Wheel on a Children's Kick Scooter: 步骤 1 中的图像 1,3 How to Fix a Skewed Wheel on a Children's Kick Scooter, How to Fix a Skewed Wheel on a Children's Kick Scooter: 步骤 1 中的图像 2,3 How to Fix a Skewed Wheel on a Children's Kick Scooter, How to Fix a Skewed Wheel on a Children's Kick Scooter: 步骤 1 中的图像 3,3
    • Remove the two bottom 16 mm pan head screws using a Phillips #1 screwdriver.
  2. How to Fix a Skewed Wheel on a Children's Kick Scooter: 步骤 2 中的图像 1,3 How to Fix a Skewed Wheel on a Children's Kick Scooter: 步骤 2 中的图像 2,3 How to Fix a Skewed Wheel on a Children's Kick Scooter: 步骤 2 中的图像 3,3
    • Remove the two 12 mm button head screws on top using a 4 mm Allen wrench.
  3. How to Fix a Skewed Wheel on a Children's Kick Scooter: 步骤 3 中的图像 1,3 How to Fix a Skewed Wheel on a Children's Kick Scooter: 步骤 3 中的图像 2,3 How to Fix a Skewed Wheel on a Children's Kick Scooter: 步骤 3 中的图像 3,3
    • Remove the plastic case from the base of the scooter.
  4. How to Fix a Skewed Wheel on a Children's Kick Scooter: 步骤 4 中的图像 1,3 How to Fix a Skewed Wheel on a Children's Kick Scooter: 步骤 4 中的图像 2,3 How to Fix a Skewed Wheel on a Children's Kick Scooter: 步骤 4 中的图像 3,3
    • Carefully pull the sides of the wheels up and remove them from the spring.
  5. How to Fix a Skewed Wheel on a Children's Kick Scooter: 步骤 5 中的图像 1,3 How to Fix a Skewed Wheel on a Children's Kick Scooter: 步骤 5 中的图像 2,3 How to Fix a Skewed Wheel on a Children's Kick Scooter: 步骤 5 中的图像 3,3
    • Grab the spring with combination pliers and bend it into a straight position.
    • Don't bend the spring too much as it could snap and replacement would be needed.
  6. How to Fix a Skewed Wheel on a Children's Kick Scooter: 步骤 6 中的图像 1,3 How to Fix a Skewed Wheel on a Children's Kick Scooter: 步骤 6 中的图像 2,3 How to Fix a Skewed Wheel on a Children's Kick Scooter: 步骤 6 中的图像 3,3
    • Insert the spring into the center section of the wheels.
    • Slide the two rings on the sides of the wheels into the two rods.
  7. How to Fix a Skewed Wheel on a Children's Kick Scooter: 步骤 7 中的图像 1,3 How to Fix a Skewed Wheel on a Children's Kick Scooter: 步骤 7 中的图像 2,3 How to Fix a Skewed Wheel on a Children's Kick Scooter: 步骤 7 中的图像 3,3
    • Insert the plastic case back into its original position.
  8. How to Fix a Skewed Wheel on a Children's Kick Scooter: 步骤 8 中的图像 1,3 How to Fix a Skewed Wheel on a Children's Kick Scooter: 步骤 8 中的图像 2,3 How to Fix a Skewed Wheel on a Children's Kick Scooter: 步骤 8 中的图像 3,3
    • Insert and tighten the two 12 mm button head screws on top using a 4 mm Allen wrench.
  9. How to Fix a Skewed Wheel on a Children's Kick Scooter: 步骤 9 中的图像 1,3 How to Fix a Skewed Wheel on a Children's Kick Scooter: 步骤 9 中的图像 2,3 How to Fix a Skewed Wheel on a Children's Kick Scooter: 步骤 9 中的图像 3,3
    • Replace the two bottom 16 mm pan head screws using a Phillips #1 screwdriver.
终点
Amir Issagali
于01/10/21注册
169 声望
撰写一个指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 36
总计 1,407
