简介
This guide details how to repair a Samsung Galaxy S10+ that will not power on.
视频概述
Check the state of the motherboard. Both the power integrated circuit (IC) and camera IC have been soldered before.
Install the motherboard to test it. Connect the display and the power cable. The motherboard shows a current leakage of 52 mA.
Press the power button. Here, the reading has not changed. Therefore, the main power supply line of the motherboard may be faulty.
Measure several power supply lines of the motherboard using the multimeter's diode mode. Inductor L5039 is shorted to the ground.
Align the new IC. Solder it with a hot air gun set to 340°C and airflow 2. Once the motherboard has cooled, connect the power cable.
Trigger the boot-up with tweezers. The boot current returns to normal.
Install the motherboard. The phone turns on normally. The fault has been cleared.
3等其他人完成本指南。
