跳转到主内容
How to Fix a Ripped Belt Loop on a Pair of Jeans
你所需要的
  1. How to Fix a Ripped Belt Loop on a Pair of Jeans, How to Fix a Ripped Belt Loop on a Pair of Jeans: 步骤 1 中的图像 1,1
    • Identify where on the pair of pants/jeans the belt loop has been torn.
  2. How to Fix a Ripped Belt Loop on a Pair of Jeans: 步骤 2 中的图像 1,2 How to Fix a Ripped Belt Loop on a Pair of Jeans: 步骤 2 中的图像 2,2
    • Thread one end of the thread through the eye hole at the top of the needle.
    • The thread must be through the eye of the needle as shown with extra thread past the eye or else the thread will fall out during sewing.
  3. How to Fix a Ripped Belt Loop on a Pair of Jeans: 步骤 3 中的图像 1,1
    • Push the needle through from the back to the front of the pants making sure to pierce both the belt loop and the pants.
  4. How to Fix a Ripped Belt Loop on a Pair of Jeans: 步骤 4 中的图像 1,2 How to Fix a Ripped Belt Loop on a Pair of Jeans: 步骤 4 中的图像 2,2
    • Repeat the process in and out of the pants.
    • When you get to the right end of the belt loop continue the process back to where you began.
  5. How to Fix a Ripped Belt Loop on a Pair of Jeans: 步骤 5 中的图像 1,2 How to Fix a Ripped Belt Loop on a Pair of Jeans: 步骤 5 中的图像 2,2
    • Tie the thread together three to four times with a basic knot and cut the excess.
    • Tug the belt loop to check if it is secure.
    • If the belt loop does not budge you have successfully followed this guide.
    • If it does not budge you will need to remove the thread and restart from Step 3.
结论
2等其他人完成本指南。
[deleted]
于09/29/20注册
175 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 17
过去 7 天: 146
过去 30 天: 538
总计 10,322
