跳转到主内容
How to Fix a Razer Naga Trinity Click Button
你所需要的
  1. How to Fix a Razer Naga Trinity Click Button, How to Fix a Razer Naga Trinity Click Button: 步骤 1 中的图像 1,3 How to Fix a Razer Naga Trinity Click Button, How to Fix a Razer Naga Trinity Click Button: 步骤 1 中的图像 2,3 How to Fix a Razer Naga Trinity Click Button, How to Fix a Razer Naga Trinity Click Button: 步骤 1 中的图像 3,3
    • Remove the three pads from the bottom of the mouse.
    • Remove the four screws beneath the pads using a JIS #1 screwdriver.
  2. How to Fix a Razer Naga Trinity Click Button: 步骤 2 中的图像 1,2 How to Fix a Razer Naga Trinity Click Button: 步骤 2 中的图像 2,2
    • Press the top of mouse and pull back to disconnect the mouse shell.
    • Pull out the cord that connects the RGB button.
  3. How to Fix a Razer Naga Trinity Click Button: 步骤 3 中的图像 1,2 How to Fix a Razer Naga Trinity Click Button: 步骤 3 中的图像 2,2
    • Remove the right shell.
    • Disconnect the cable connecting the left shell to the mouse.
    • Remove the left shell.
  4. How to Fix a Razer Naga Trinity Click Button: 步骤 4 中的图像 1,1
    • Use a safety pin to unlatch the clicker buttons.
  5. How to Fix a Razer Naga Trinity Click Button: 步骤 5 中的图像 1,2 How to Fix a Razer Naga Trinity Click Button: 步骤 5 中的图像 2,2
    • Insert the open safety pin to lift one side latch slightly.
    • Do not open the whole part.
    • Repeat for the other side.
  6. How to Fix a Razer Naga Trinity Click Button: 步骤 6 中的图像 1,3 How to Fix a Razer Naga Trinity Click Button: 步骤 6 中的图像 2,3 How to Fix a Razer Naga Trinity Click Button: 步骤 6 中的图像 3,3
    • Remove the clicker and white pin.
    • Gently press the middle part of the copper sheet until it unhooks itself.
    • Pull the bended part of the copper sheet back.
  7. How to Fix a Razer Naga Trinity Click Button: 步骤 7 中的图像 1,1
    • Reassemble the copper sheet with the white pin seated properly.
    • Push the spring down into its place using a spudger.
    • You will hear a click sound if you successfully assemble it.
结论
4等其他人完成本指南。
Haoran Ke
于01/13/22注册
283 声望
撰写一个指南
团队
1指南评论
On the latest version of the mouse, the clicker button can no longer be opened...
Jérémie PLAYOUT - 回复
添加评论
浏览统计数据:
过去 24 小时: 9
过去 7 天: 44
过去 30 天: 291
总计 14,031
