跳转到主内容
How to Fix a Rattling Door
你所需要的
  1. How to Fix a Rattling Door, How to Fix a Rattling Door: 步骤 1 中的图像 1,3 How to Fix a Rattling Door, How to Fix a Rattling Door: 步骤 1 中的图像 2,3 How to Fix a Rattling Door, How to Fix a Rattling Door: 步骤 1 中的图像 3,3
    • Remove the strike plate on the door by unscrewing the screws that attach it to the door frame.
    • The type of screwdriver you need depends on the type of screws that hold your strike plate in your door.
  2. How to Fix a Rattling Door: 步骤 2 中的图像 1,2 How to Fix a Rattling Door: 步骤 2 中的图像 2,2
    • Take the strike plate and put it in your hand. Using the pliers in your other hand, bend the metal tab toward the flat side of the strike plate.
  3. How to Fix a Rattling Door: 步骤 3 中的图像 1,2 How to Fix a Rattling Door: 步骤 3 中的图像 2,2
    • Place the strike plate back on the door frame and tighten the screws.
结论
Close your door and shake it back and forth to see if it is still loose. Repeat the guide steps as necessary.
2等其他人完成本指南。
Sara Novell
于04/08/15注册
209 声望
撰写一个指南
团队
Cal Poly, Team 30-4, Green Spring 2015 Cal Poly, Team 30-4, Green Spring 2015 的会员
CPSU-GREEN-S15S30G4
5 名成员
创作了7篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 6
过去 30 天: 32
总计 40,399
