跳转到主内容
How to Fix a Paper Jam From the Rear in a Canon Pixma TR4520
你所需要的
  1. How to Fix a Paper Jam From the Rear in a Canon Pixma TR4520, How to Fix a Paper Jam From the Rear in a Canon Pixma TR4520: 步骤 1 中的图像 1,1
    • Press Stop to cancel the print job.
  2. How to Fix a Paper Jam From the Rear in a Canon Pixma TR4520: 步骤 2 中的图像 1,2 How to Fix a Paper Jam From the Rear in a Canon Pixma TR4520: 步骤 2 中的图像 2,2
    • Turn off the printer.
    • Unplug your printer from the power source.
  3. How to Fix a Paper Jam From the Rear in a Canon Pixma TR4520: 步骤 3 中的图像 1,2 How to Fix a Paper Jam From the Rear in a Canon Pixma TR4520: 步骤 3 中的图像 2,2
    • Open the front tray and check for jammed paper.
    • If you don't see any jammed paper, skip to step 5.
  4. How to Fix a Paper Jam From the Rear in a Canon Pixma TR4520: 步骤 4 中的图像 1,2 How to Fix a Paper Jam From the Rear in a Canon Pixma TR4520: 步骤 4 中的图像 2,2
    • Pull the paper out slowly using both of your hands to avoid tearing.
    • If paper tears apart, do not force the paper out. You can remove any remaining paper by accessing the back panel.
    • If you were able to remove all of the jammed paper through the front, there's no need to continue! Simply proceed using your printer as normal.
  5. How to Fix a Paper Jam From the Rear in a Canon Pixma TR4520: 步骤 5 中的图像 1,3 How to Fix a Paper Jam From the Rear in a Canon Pixma TR4520: 步骤 5 中的图像 2,3 How to Fix a Paper Jam From the Rear in a Canon Pixma TR4520: 步骤 5 中的图像 3,3
    • Lay the printer on its backside to expose the bottom panel.
    • Remove the two screws holding the transport unit cover in place with a Phillips #1 screwdriver.
  6. How to Fix a Paper Jam From the Rear in a Canon Pixma TR4520: 步骤 6 中的图像 1,2 How to Fix a Paper Jam From the Rear in a Canon Pixma TR4520: 步骤 6 中的图像 2,2
    • Lift off the transport unit cover.
    • Be gentle while removing the cover. You don't want to damage it.
  7. How to Fix a Paper Jam From the Rear in a Canon Pixma TR4520: 步骤 7 中的图像 1,2 How to Fix a Paper Jam From the Rear in a Canon Pixma TR4520: 步骤 7 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Remove any remaining paper gently either using your fingers or a pair of tweezers.
结论
2等其他人完成本指南。
团队
7条评论
can you show the whole bottom without the tray being in the way? I would really appreciate!
Lex - 回复
it still has the two lights blinking
kresge - 回复
directions did not help, the yellow and ogange till blinks
kresge - 回复
it did not work
kresge - 回复
Papers stuck it won’t budge I’m underneath and it’s gripped it like a vice! Didn’t work where do we go from here this is horrible!
Leah Campbell - 回复
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 46
过去 30 天: 234
总计 11,465
