跳转到主内容
How to Fix a Non-Sticky Cutting Mat
你所需要的
  1. How to Fix a Non-Sticky Cutting Mat, How to Fix a Non-Sticky Cutting Mat: 步骤 1 中的图像 1,1
    • Place the non-sticky mat on a flat surface.
  2. How to Fix a Non-Sticky Cutting Mat: 步骤 2 中的图像 1,1
    • Spray the non-sticky cutting mat with a spray cleaner covering the entire mat.
  3. How to Fix a Non-Sticky Cutting Mat: 步骤 3 中的图像 1,1
    • Let it sit for 5-10 minutes.
  4. How to Fix a Non-Sticky Cutting Mat: 步骤 4 中的图像 1,1
    • Use a scraper to gently push the dirt off the mat that is causing your cutting mat not to be sticky.
  5. How to Fix a Non-Sticky Cutting Mat: 步骤 5 中的图像 1,1
    • Once all the dirt is removed, let it air dry.
  6. How to Fix a Non-Sticky Cutting Mat: 步骤 6 中的图像 1,1
    • Once dry, make sure to cover the cutting mat with its plastic cover to avoid the dust sticking to it.
终点
April Pantaleon
于09/20/20注册
349 声望
创作了2篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 12
总计 404
