跳转到主内容
How to Fix a Noisy/Squeaky Bicycle Chain
你所需要的
  1. How to Fix a Noisy/Squeaky Bicycle Chain, How to Fix a Noisy/Squeaky Bicycle Chain: 步骤 1 中的图像 1,3 How to Fix a Noisy/Squeaky Bicycle Chain, How to Fix a Noisy/Squeaky Bicycle Chain: 步骤 1 中的图像 2,3 How to Fix a Noisy/Squeaky Bicycle Chain, How to Fix a Noisy/Squeaky Bicycle Chain: 步骤 1 中的图像 3,3
    • Place a piece of cardboard under the bicycle to catch excess cleaner.
    • Rotate the foot pedal with your hand slowly, and spray WD-40 bicycle chain cleaner evenly throughout the chain.
    • Only use WD-40 that is specifically made for bicycles. Using normal WD-40 can damage your bicycle chain.
    • The chemical spray is toxic and very unpleasant to smell. Please use a mask or other means of protection on your face and eyes.
  2. How to Fix a Noisy/Squeaky Bicycle Chain: 步骤 2 中的图像 1,3 How to Fix a Noisy/Squeaky Bicycle Chain: 步骤 2 中的图像 2,3 How to Fix a Noisy/Squeaky Bicycle Chain: 步骤 2 中的图像 3,3
    • Use bicycle cleaning tools to clean the bicycle chain, the chainrings, the cogset, and front & rear derailleurs until most of the rust is gone.
    • Some bicycles do not have all of these parts.
  3. How to Fix a Noisy/Squeaky Bicycle Chain: 步骤 3 中的图像 1,2 How to Fix a Noisy/Squeaky Bicycle Chain: 步骤 3 中的图像 2,2
    • Check your chain system, not only on the chain, but also on the chainrings, cogset, and derailleur system. Sometimes this part will also make noises because of rust.
    • Drip the WD-40 bicycle lubricant on one spot of the chain and rotate the foot pedal until the whole chain is lubricated.
    • Repeat this process until the chain no longer squeaks.
终点
Jiaming Liu
于09/19/20注册
97 声望
撰写一个指南
团队
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 21
总计 2,809
