跳转到主内容
How to Fix a Noisy Table Fan
你所需要的
  1. How to Fix a Noisy Table Fan, How to Fix a Noisy Table Fan: 步骤 1 中的图像 1,2 How to Fix a Noisy Table Fan, How to Fix a Noisy Table Fan: 步骤 1 中的图像 2,2
    • Before starting the fix, be sure to turn off and unplug the fan.
    • Place your fan on a clear, open level area, like a table top.
    • It may help to place a towel underneath the fan, as it will catch some of the falling debris.
  2. How to Fix a Noisy Table Fan: 步骤 2 中的图像 1,3 How to Fix a Noisy Table Fan: 步骤 2 中的图像 2,3 How to Fix a Noisy Table Fan: 步骤 2 中的图像 3,3
    • Remove the clamps surrounding the protective cage by pulling each outward (away from the fan) one at a time.
    • Though this may require some force, don't pull on the clamps too hard, as they can be easily broken.
    • As you are removing the last few clamps, be sure to hold the cage with another hand. Otherwise, it will fall right off!
    • Once the front end of the cage is free, remove it from the fan and place it to the side for now.
  3. How to Fix a Noisy Table Fan: 步骤 3 中的图像 1,3 How to Fix a Noisy Table Fan: 步骤 3 中的图像 2,3 How to Fix a Noisy Table Fan: 步骤 3 中的图像 3,3
    • Now that the blades are exposed, it's time to remove them. Holding the blade piece in place with another hand, twist off the knob in the center of the piece.
    • Take note of the direction that you should be spinning the knob for loosening, which is labeled as clockwise on this fan (not lefty-loosy!) If you're having trouble twisting the knob off, you may be twisting it the wrong way!
    • Once loosend enough, the knob should spin right off.
  4. How to Fix a Noisy Table Fan: 步骤 4 中的图像 1,2 How to Fix a Noisy Table Fan: 步骤 4 中的图像 2,2
    • With the knob removed, these blades can come off!
    • Pull the blade piece straight off the rotor, using your other arm to weigh down the rest of the fan.
    • Set the blade piece to the side alongside the first half of the cage.
  5. How to Fix a Noisy Table Fan: 步骤 5 中的图像 1,3 How to Fix a Noisy Table Fan: 步骤 5 中的图像 2,3 How to Fix a Noisy Table Fan: 步骤 5 中的图像 3,3
    • Now to remove the second half of the cage. Do this by first removing the knob surrounding the rotor.
    • Like the first knob, be sure to check for the labelings to see which direction you should be turning. On this fan, I have to twist counter-clockwise this time (this time, lefty-loosy!).
  6. How to Fix a Noisy Table Fan: 步骤 6 中的图像 1,3 How to Fix a Noisy Table Fan: 步骤 6 中的图像 2,3 How to Fix a Noisy Table Fan: 步骤 6 中的图像 3,3
    • With this knob off, you can now slide the other half of the cage off.
    • When reassembling the fan, remember to slide this half of the cage back on by aligning the holes in the metal center of the cage with the stumps sticking out on the fan.
    • With all the easily-detachable parts of the fan off, you should now be left with a bare fan.
  7. How to Fix a Noisy Table Fan: 步骤 7 中的图像 1,3 How to Fix a Noisy Table Fan: 步骤 7 中的图像 2,3 How to Fix a Noisy Table Fan: 步骤 7 中的图像 3,3
    • Time to get down to cleaning! First, the fan blades. Do not immerse the fan in water and never allow water to drip into the motor housing.
    • Dampen your wash cloth with warm water and begin wiping down the surface of the blades. Never use gasoline, benzene, or thinner to clean the fan. This will damage the surface of the fan.
    • Be sure to clean all the nooks and crannies. Let the piece dry.
  8. How to Fix a Noisy Table Fan: 步骤 8 中的图像 1,2 How to Fix a Noisy Table Fan: 步骤 8 中的图像 2,2
    • Next, the protective cage.
    • This procedure is similar to that for cleaning the blades: use your dampened cloth to wipe down both sides of each cage.
  9. How to Fix a Noisy Table Fan: 步骤 9 中的图像 1,2 How to Fix a Noisy Table Fan: 步骤 9 中的图像 2,2
    • Finally, the rest of the fan.
    • Like in the last two steps, wipe down the rotor and the area surrounding it on the fan. After cleaning, be sure to completely dry the fan with a cloth or towel before using it.
    • For further cleaning, spray compressed air into the fan to help free the area surrounding the motor of debris and thus improve the longevity of the fan.
    • Voila! Your fan should be (almost) as good as new! Be sure to repeat this often for proper fan maintenance (once every one or two weeks should suffice, depending on your fan usage).
结论
Note: It may be easier to reassemble your fan with it lying down with the rotor facing up, as it allows gravity to hold certain pieces in place for you.
24等其他人完成本指南。
Codi Barnett
于09/29/15注册
815 声望
撰写一个指南
团队
Cal Poly, Team 15-5, Green Fall 2015 Cal Poly, Team 15-5, Green Fall 2015 的会员
CPSU-GREEN-F15S15G5
4 名成员
创作了15篇指南
10指南评论
Worked like a charm. I had a noisy pedestal fan in my bedroom that's only used during the summer, but it got noisy enough to wake us up. Now it's nice and quiet. I also made a cover for it to keep the dust out when it's being stored during winter. Our fan had the directions that the various pieces were to be turned to tighten them imprinted on the pieces themselves. It's an 18-year-old Lasko pedestal fan, and I'd cleaned it before, but not as thoroughly as the instructions indicated.
vegakitty - 回复
my fan is brand new.it makes a creeky squeeky sound every time it turns to the right.i know how to put a fan together,but i've never tried to see if i can open up a motor to see if i can hear where it is originating from.i think the joint is too tight in the arm maybe.i can't find anyone who knows who can fix it-no electrician knows.i also have problem finding someone who can install an apartment ac,for when i need a new ac-no ac business has a clue!
natalie charney - 回复
My fan seems like it has lost it's balance....it makes ticking sound while rotating.... Seems like it's neck is broken... What should I do...???
Priyanka - 回复
First Go to the old things man with Ur f***Kng fan n sell them after that u buy a new fan…teky
Kiran Darling Jain -
wow !!! it is nice article about learning how to fix a noisy table fan.
Medcard Now - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 50
过去 30 天: 206
总计 211,013
