跳转到主内容
How to Fix a Loose Turret on a Sony Cyber-shot DSC-F828
你所需要的
  1. How to Fix a Loose Turret on a Sony Cyber-shot DSC-F828, How to Fix a Loose Turret on a Sony Cyber-shot DSC-F828: 步骤 1 中的图像 1,2 How to Fix a Loose Turret on a Sony Cyber-shot DSC-F828, How to Fix a Loose Turret on a Sony Cyber-shot DSC-F828: 步骤 1 中的图像 2,2
    • Slide the button back to open the battery cover.
  2. How to Fix a Loose Turret on a Sony Cyber-shot DSC-F828: 步骤 2 中的图像 1,2 How to Fix a Loose Turret on a Sony Cyber-shot DSC-F828: 步骤 2 中的图像 2,2
    • Pull back on the tab to release the battery.
    • Pull the battery out, then close the lid.
  3. How to Fix a Loose Turret on a Sony Cyber-shot DSC-F828: 步骤 3 中的图像 1,1
    • Remove the screw on the back of the turret with a JIS #00 screwdriver.
  4. How to Fix a Loose Turret on a Sony Cyber-shot DSC-F828: 步骤 4 中的图像 1,2 How to Fix a Loose Turret on a Sony Cyber-shot DSC-F828: 步骤 4 中的图像 2,2
    • Remove two screws from each side of the camera (four in total) using a JIS #00 screwdriver.
  5. How to Fix a Loose Turret on a Sony Cyber-shot DSC-F828: 步骤 5 中的图像 1,1
    • Remove the screw on the bottom of the turret using a JIS #00 screwdriver.
  6. How to Fix a Loose Turret on a Sony Cyber-shot DSC-F828: 步骤 6 中的图像 1,1
    • Carefully pull the face plate off and lay it down.
    • There is a cable attached to the plate that should not be removed.
  7. How to Fix a Loose Turret on a Sony Cyber-shot DSC-F828: 步骤 7 中的图像 1,2 How to Fix a Loose Turret on a Sony Cyber-shot DSC-F828: 步骤 7 中的图像 2,2
    • Tighten the two screws using a JIS #00 screwdriver.
结论
5等其他人完成本指南。
一条评论
Thanks, I just used this to tighten the pivot on an F828 I got on eBay. Super easy.
photoman12001 - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 43
总计 1,112
