跳转到主内容
How to Fix a Loose Oven Handle
你所需要的
  1. How to Fix a Loose Oven Handle, How to Fix a Loose Oven Handle: 步骤 1 中的图像 1,2 How to Fix a Loose Oven Handle, How to Fix a Loose Oven Handle: 步骤 1 中的图像 2,2
    • Open the oven and unlock hinges that are located at the bottom of each side of the oven.
  2. How to Fix a Loose Oven Handle: 步骤 2 中的图像 1,2 How to Fix a Loose Oven Handle: 步骤 2 中的图像 2,2
    • Lift the door up and detach from the oven.
    • Place the door on the floor or any other flat surface.
  3. How to Fix a Loose Oven Handle: 步骤 3 中的图像 1,2 How to Fix a Loose Oven Handle: 步骤 3 中的图像 2,2
    • Unfasten the top 2 screws of the inside of the door ( the ones holding the handle).
    • For this specific oven, a Phillips #0 screwdriver was used. Make sure to check which screw driver fits your oven screws.
  4. How to Fix a Loose Oven Handle: 步骤 4 中的图像 1,1
    • Observe the screws.
    • If rusty, cleanse them. If damaged, replace with new ones.
  5. How to Fix a Loose Oven Handle: 步骤 5 中的图像 1,1
    • Reset and fasten the screws back in tightly.
  6. How to Fix a Loose Oven Handle: 步骤 6 中的图像 1,2 How to Fix a Loose Oven Handle: 步骤 6 中的图像 2,2
    • Place the door back to the oven.
    • Refasten the hinges.
  7. How to Fix a Loose Oven Handle: 步骤 7 中的图像 1,1
    • Test the handle
结论
4等其他人完成本指南。
3指南评论
I'm glad to hear that you found the article informative! My goal is to provide accurate and helpful information to anyone who asks. If you have any more questions or topics you'd like to learn about, feel free to ask!
Ava Dave - 回复
δεν κλείνει καλά η πόρτα της κουζίνας. αφήνει κενό επάνω.
Dimitris Georg - 回复
What would I wrap around screw to make a tighter connection; plumber tape, string, super glue?
stevereicher - 回复
添加评论
浏览统计数据:
过去 24 小时: 7
过去 7 天: 92
过去 30 天: 415
总计 50,122
