跳转到主内容
How to Fix a Loose Louver in Wooden Sliding Shutters
你所需要的
  1. How to Fix a Loose Louver in Wooden Sliding Shutters, How to Fix a Loose Louver in Wooden Sliding Shutters: 步骤 1 中的图像 1,1
    • Clean the louvers with the disinfectant wipes.
  2. How to Fix a Loose Louver in Wooden Sliding Shutters: 步骤 2 中的图像 1,1
    • Locate the broken or loose louver.
  3. How to Fix a Loose Louver in Wooden Sliding Shutters: 步骤 3 中的图像 1,2 How to Fix a Loose Louver in Wooden Sliding Shutters: 步骤 3 中的图像 2,2
    • Align the louvers so they are parallel to the ground.
    • Make sure the knob is facing the tilt bar NOT away from it.
  4. How to Fix a Loose Louver in Wooden Sliding Shutters: 步骤 4 中的图像 1,1
    • Tilt the louver down creating a 30 degree angle with the bar.
  5. How to Fix a Loose Louver in Wooden Sliding Shutters: 步骤 5 中的图像 1,1
    • Position the knob in between the two holes.
  6. How to Fix a Loose Louver in Wooden Sliding Shutters: 步骤 6 中的图像 1,1
    • Insert the pin into the two holes.
  7. How to Fix a Loose Louver in Wooden Sliding Shutters: 步骤 7 中的图像 1,2 How to Fix a Loose Louver in Wooden Sliding Shutters: 步骤 7 中的图像 2,2
    • Push and secure the pin.
  8. How to Fix a Loose Louver in Wooden Sliding Shutters: 步骤 8 中的图像 1,2 How to Fix a Loose Louver in Wooden Sliding Shutters: 步骤 8 中的图像 2,2
    • You are finished!
终点
Fatima Sakhri
于05/08/20注册
157 声望
撰写一个指南
团队
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 3
过去 30 天: 14
总计 1,416
