跳转到主内容
How to Fix a Loose Light Socket on a Lamp Model L37721
你所需要的
  1. How to Fix a Loose Light Socket on a Lamp Model L37721, How to Fix a Loose Light Socket on a Lamp Model L37721: 步骤 1 中的图像 1,1
    • Unplug the lamp from the electrical socket.
    • Ensure that there is no electrical charge in the lamp by turning the lamp on and off.
  2. How to Fix a Loose Light Socket on a Lamp Model L37721: 步骤 2 中的图像 1,3 How to Fix a Loose Light Socket on a Lamp Model L37721: 步骤 2 中的图像 2,3 How to Fix a Loose Light Socket on a Lamp Model L37721: 步骤 2 中的图像 3,3
    • Turn the lamp shade knob in a counterclockwise direction to remove it.
    • Lift the lampshade to remove it.
  3. How to Fix a Loose Light Socket on a Lamp Model L37721: 步骤 3 中的图像 1,2 How to Fix a Loose Light Socket on a Lamp Model L37721: 步骤 3 中的图像 2,2
    • Turn the light bulb in a counterclockwise direction to remove it.
  4. How to Fix a Loose Light Socket on a Lamp Model L37721: 步骤 4 中的图像 1,2 How to Fix a Loose Light Socket on a Lamp Model L37721: 步骤 4 中的图像 2,2
    • Lift the tabs up from the base.
    • Squeeze the lamp shade posts inward to release them.
  5. How to Fix a Loose Light Socket on a Lamp Model L37721: 步骤 5 中的图像 1,2 How to Fix a Loose Light Socket on a Lamp Model L37721: 步骤 5 中的图像 2,2
    • Place the flat side of the screwdriver against the flat side of the nut inside of the base.
  6. How to Fix a Loose Light Socket on a Lamp Model L37721: 步骤 6 中的图像 1,2 How to Fix a Loose Light Socket on a Lamp Model L37721: 步骤 6 中的图像 2,2
    • While placing pressure against the nut, grip the light socket and turn it in a clockwise direction until it is tight against the base.
结论
Robert McNabb
于03/26/20注册
133 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 14
过去 30 天: 63
总计 5,571
