简介
This guide will show you how to repair the gate latch of a wood fence gate, if the original screw holes are worn out or loose. If this happens the hardware may be misaligned or ineffective. We will use anchors and other common tools to tighten the connection and reinforce the hardware.
If you're unable to remove and replace the gate latch or there is not a good secondary location for the placement of gate latches, follow this guide. This repair takes minor knowledge of using basic hand tools such as an electric drill, hammer, and sander. It is still achievable for those with almost no background skill in carpentry or construction.
你所需要的
Remove all screws and bolts holding your gate latch down.
Using a hammer, tap in the sleeve anchors with the washer and bolt still attached, to prevent the sleeve and anchor bolt from separating.
Keep tapping the sleeve anchor until most of the sleeve is seated in the wood while leaving 12.7 mm of thread protruding from the wood.
Remove the bolts and washers from Sleeve Anchors once they have been inserted into the piloted holes.
