跳转到主内容
How to Fix a Loose Cookware Lid Handle
  1. How to Fix a Loose Cookware Lid Handle, How to Fix a Loose Cookware Lid Handle: 步骤 1 中的图像 1,1
    • Wash the glass of the lid with hot water.
    • Be sure to scrub underneath and around the handle.
  2. How to Fix a Loose Cookware Lid Handle: 步骤 2 中的图像 1,1
    • Clean the glass lid with a dry piece of cloth.
    • Make sure to especially clean below and around the handle.
  3. How to Fix a Loose Cookware Lid Handle: 步骤 3 中的图像 1,2 How to Fix a Loose Cookware Lid Handle: 步骤 3 中的图像 2,2
    • Unscrew the handle from the lid and remove the screw and washer.
  4. How to Fix a Loose Cookware Lid Handle: 步骤 4 中的图像 1,2 How to Fix a Loose Cookware Lid Handle: 步骤 4 中的图像 2,2
    • Clean the hole of the handle with a drop of vinegar and baking soda.
    • Firmly apply the drop of vinegar and baking soda below and underneath the hole, which will clear the surface of any dirt.
  5. How to Fix a Loose Cookware Lid Handle: 步骤 5 中的图像 1,3 How to Fix a Loose Cookware Lid Handle: 步骤 5 中的图像 2,3 How to Fix a Loose Cookware Lid Handle: 步骤 5 中的图像 3,3
    • Clean the screw and washer with a drop of vinegar and baking soda.
    • Allow the parts to dry for about 1-2 minutes.
  6. How to Fix a Loose Cookware Lid Handle: 步骤 6 中的图像 1,2 How to Fix a Loose Cookware Lid Handle: 步骤 6 中的图像 2,2
    • Apply super glue around the hole of the handle.
    • Be cautious when using super glue that you don't spill it over the bigger glass surface.
  7. How to Fix a Loose Cookware Lid Handle: 步骤 7 中的图像 1,3 How to Fix a Loose Cookware Lid Handle: 步骤 7 中的图像 2,3 How to Fix a Loose Cookware Lid Handle: 步骤 7 中的图像 3,3
    • Quickly install the handle back onto the lid using the screw and washer.
    • Be careful not to touch the glue with your fingers.
    • Once again keep it dry for about 4-5 minutes.
    • The loose handle on your glass lid is fixed and ready to use.
结论
Dinuk Warnapura
于01/11/21注册
145 声望
撰写一个指南
团队
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 12
过去 30 天: 47
总计 2,943
