跳转到主内容
How to Fix a Loose Connector in an Anivia 1080p Webcam
你所需要的
  1. How to Fix a Loose Connector in an Anivia 1080p Webcam, How to Fix a Loose Connector in an Anivia 1080p Webcam: 步骤 1 中的图像 1,3 How to Fix a Loose Connector in an Anivia 1080p Webcam, How to Fix a Loose Connector in an Anivia 1080p Webcam: 步骤 1 中的图像 2,3 How to Fix a Loose Connector in an Anivia 1080p Webcam, How to Fix a Loose Connector in an Anivia 1080p Webcam: 步骤 1 中的图像 3,3
    • Pry open the face plate of the webcam using the iFixit opening pick or another safe tool, and set it aside.
  2. How to Fix a Loose Connector in an Anivia 1080p Webcam: 步骤 2 中的图像 1,3 How to Fix a Loose Connector in an Anivia 1080p Webcam: 步骤 2 中的图像 2,3 How to Fix a Loose Connector in an Anivia 1080p Webcam: 步骤 2 中的图像 3,3
    • Remove the three main screws using a Phillips screwdriver while carefully holding the camera motherboard in place.
  3. How to Fix a Loose Connector in an Anivia 1080p Webcam: 步骤 3 中的图像 1,3 How to Fix a Loose Connector in an Anivia 1080p Webcam: 步骤 3 中的图像 2,3 How to Fix a Loose Connector in an Anivia 1080p Webcam: 步骤 3 中的图像 3,3
    • Remove the camera and motherboard from the casing carefully.
  4. How to Fix a Loose Connector in an Anivia 1080p Webcam: 步骤 4 中的图像 1,3 How to Fix a Loose Connector in an Anivia 1080p Webcam: 步骤 4 中的图像 2,3 How to Fix a Loose Connector in an Anivia 1080p Webcam: 步骤 4 中的图像 3,3
    • Detach the cable from the connecter on the motherboard.
    • Pull from the plastic as to not damage any of the wires.
  5. How to Fix a Loose Connector in an Anivia 1080p Webcam: 步骤 5 中的图像 1,3 How to Fix a Loose Connector in an Anivia 1080p Webcam: 步骤 5 中的图像 2,3 How to Fix a Loose Connector in an Anivia 1080p Webcam: 步骤 5 中的图像 3,3
    • Identify where the connector is loose and solder the piece back into place.
    • Use only as little solder as needed to keep functionality in tact.
    • Caution: The soldering iron is hot and should be handled with care.
  6. How to Fix a Loose Connector in an Anivia 1080p Webcam: 步骤 6 中的图像 1,2 How to Fix a Loose Connector in an Anivia 1080p Webcam: 步骤 6 中的图像 2,2
    • Reattach the cable to the connector.
  7. How to Fix a Loose Connector in an Anivia 1080p Webcam: 步骤 7 中的图像 1,2 How to Fix a Loose Connector in an Anivia 1080p Webcam: 步骤 7 中的图像 2,2
    • Place the motherboard and camera back into the casing.
  8. How to Fix a Loose Connector in an Anivia 1080p Webcam: 步骤 8 中的图像 1,3 How to Fix a Loose Connector in an Anivia 1080p Webcam: 步骤 8 中的图像 2,3 How to Fix a Loose Connector in an Anivia 1080p Webcam: 步骤 8 中的图像 3,3
    • Screw the camera and motherboard back into place.
  9. How to Fix a Loose Connector in an Anivia 1080p Webcam: 步骤 9 中的图像 1,3 How to Fix a Loose Connector in an Anivia 1080p Webcam: 步骤 9 中的图像 2,3 How to Fix a Loose Connector in an Anivia 1080p Webcam: 步骤 9 中的图像 3,3
    • Snap the faceplate covering back into place.
终点
Duncan Holloway
于02/24/21注册
169 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 11
过去 30 天: 44
总计 1,537
