跳转到主内容
How to Fix a Loose Connection on a Power Strip
你所需要的
  1. How to Fix a Loose Connection on a Power Strip, How to Fix a Loose Connection on a Power Strip: 步骤 1 中的图像 1,1
    • Before you start, make sure you unplug the power strip from the wall! It is very important, as you will get an electric shock if you do not do so.
    • Take out all the plugs on the power strip.
  2. How to Fix a Loose Connection on a Power Strip: 步骤 2 中的图像 1,2 How to Fix a Loose Connection on a Power Strip: 步骤 2 中的图像 2,2
    • Flip over the power strip.
    • Use a Phillips #0 screwdriver to take out the 6 mm screws on the back of the power strip.
  3. How to Fix a Loose Connection on a Power Strip: 步骤 3 中的图像 1,2 How to Fix a Loose Connection on a Power Strip: 步骤 3 中的图像 2,2
    • Separate the outer shell from the power strip.
    • Most of the outer shells can be separated out very easily after the screws are taken out.
  4. How to Fix a Loose Connection on a Power Strip: 步骤 4 中的图像 1,2 How to Fix a Loose Connection on a Power Strip: 步骤 4 中的图像 2,2
    • Locate two pairs of copper sheets for each socket.
  5. How to Fix a Loose Connection on a Power Strip: 步骤 5 中的图像 1,3 How to Fix a Loose Connection on a Power Strip: 步骤 5 中的图像 2,3 How to Fix a Loose Connection on a Power Strip: 步骤 5 中的图像 3,3
    • Use a screwdriver to push the two copper sheets closer to each other. Do this on all the pairs of copper sheets without a solid connection.
  6. How to Fix a Loose Connection on a Power Strip: 步骤 6 中的图像 1,2 How to Fix a Loose Connection on a Power Strip: 步骤 6 中的图像 2,2
    • Install the outer shell back to the power strip.
    • Put the outer shell on it and press it to install.
  7. How to Fix a Loose Connection on a Power Strip: 步骤 7 中的图像 1,2 How to Fix a Loose Connection on a Power Strip: 步骤 7 中的图像 2,2
    • Flip over the power strip, and then use screwdriver to install all the screws back.
  8. How to Fix a Loose Connection on a Power Strip: 步骤 8 中的图像 1,1
    • Plug the power strip into the wall socket, and then plug electric machine to the power strip to test that if the connection of power strip has improved.
结论
You’re all done!
另外一个人完成了本指南。
Xike Cao
于09/19/21注册
219 声望
撰写一个指南
团队
York University, Team F-27, Woodhouse Fall 2021 York University, Team F-27, Woodhouse Fall 2021 的会员
YORK-WOODHOUSE-F21SFG27
1 名成员
创作了2篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 27
过去 30 天: 102
总计 3,075
