跳转到主内容
How to Fix a Loose Car Window
你所需要的
视频概述
  1. How to Fix a Loose Car Window, Remove Fasteners: 步骤 1 中的图像 1,3 How to Fix a Loose Car Window, Remove Fasteners: 步骤 1 中的图像 2,3 How to Fix a Loose Car Window, Remove Fasteners: 步骤 1 中的图像 3,3
    • Remove any screws securing the door's inside panel.
    • The number and location of screws will vary depending on your car model.
    • Feel underneath the door handles for additional screws, and remove them if any are present.
    • Feel around the bottom edge of the door's inside panel for additional screws.
    • If none are present, the inside panel is press-fitted, meaning you will be able to pull off the panel once all screws are removed.
  2. How to Fix a Loose Car Window, Remove Handle: 步骤 2 中的图像 1,3 How to Fix a Loose Car Window, Remove Handle: 步骤 2 中的图像 2,3 How to Fix a Loose Car Window, Remove Handle: 步骤 2 中的图像 3,3
    • If there are any screws fastening the door's handle to the inside panel, remove them.
    • Remove the door handles.
    • You may need to insert a flathead screwdriver between the handle assembly and the panel.
    • When removing the handle assembly, push towards the inside of the car door to remove the handle from its left-side clips.
    • Use your fingers or a screwdriver to unclip the handle's push rod from the handle assembly.
  3. How to Fix a Loose Car Window: 步骤 3 中的图像 1,2 How to Fix a Loose Car Window: 步骤 3 中的图像 2,2
    • If the panel is press-fit onto the door, use your hands to un-clip the panel.
  4. How to Fix a Loose Car Window: 步骤 4 中的图像 1,3 How to Fix a Loose Car Window: 步骤 4 中的图像 2,3 How to Fix a Loose Car Window: 步骤 4 中的图像 3,3
    • Use your fingers to disconnect any cables connecting the panel and the inside of the door.
    • Remove the panel from the door.
  5. How to Fix a Loose Car Window: 步骤 5 中的图像 1,1
    • Remove the plastic cover from the inside of the door to access the interior mechanisms.
  6. How to Fix a Loose Car Window: 步骤 6 中的图像 1,3 How to Fix a Loose Car Window: 步骤 6 中的图像 2,3 How to Fix a Loose Car Window: 步骤 6 中的图像 3,3
    • Use a socket wrench to loosen the bolt on the window mechanism.
    • Wipe any grease or debris from the window mechanism using a cloth.
  7. How to Fix a Loose Car Window: 步骤 7 中的图像 1,2 How to Fix a Loose Car Window: 步骤 7 中的图像 2,2
    • Use your hands to replace the window in the window clamp.
    • The window pane should fit between the two sides of the clamp.
    • Re-tighten the window clamp using a socket wrench.
    • If the window clamp does not hold the window tight enough, use polymer sealant to stick the window clamp and the glass together. Be sure to allow the sealant to set completely before trying to use the mechanism.
  8. How to Fix a Loose Car Window: 步骤 8 中的图像 1,2 How to Fix a Loose Car Window: 步骤 8 中的图像 2,2
    • Slide a putty knife between the glass window panel and the rubber door seal.
    • Pry the rubber door seal outwards and position the window in the door channel.
  9. How to Fix a Loose Car Window: 步骤 9 中的图像 1,2 How to Fix a Loose Car Window: 步骤 9 中的图像 2,2
    • If your vehicle's door includes a golf-ball-sized hole in the frame, it is likely designed to allow the user to view the other portion of the window mechanism.
    • Lower the window mechanism until you are able to view the window clamp on the inside portion of the door.
    • If the glass has become detached from the inside window mechanism, repeat steps 6 and 7 to reclamp the window to the mechanism.
结论
To reassemble your vehicle, follow steps 1 through 5 in reverse order. Be sure to replace the plastic sheet on the inside of the door using polymer sealant. This sheet is a vapor shield and is designed to prevent vapor from inside the car from getting into the window electronics and mechanisms.
2等其他人完成本指南。
jon
于05/15/16注册
2,949 声望
创作了22篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 51
过去 30 天: 197
总计 24,704
