跳转到主内容
How to Fix a Loose Arm Rest for Office Chair 068-0935-6
你所需要的
  1. How to Fix a Loose Arm Rest for Office Chair 068-0935-6, How to Fix a Loose Arm Rest for Office Chair 068-0935-6: 步骤 1 中的图像 1,3 How to Fix a Loose Arm Rest for Office Chair 068-0935-6, How to Fix a Loose Arm Rest for Office Chair 068-0935-6: 步骤 1 中的图像 2,3 How to Fix a Loose Arm Rest for Office Chair 068-0935-6, How to Fix a Loose Arm Rest for Office Chair 068-0935-6: 步骤 1 中的图像 3,3
    • Use a hex key to undo all of the M3 x 6 mm alloy steel hex bolts.
    • Turn the hex key in the counter-clockwise direction to unscrew the bolts.
  2. How to Fix a Loose Arm Rest for Office Chair 068-0935-6: 步骤 2 中的图像 1,3 How to Fix a Loose Arm Rest for Office Chair 068-0935-6: 步骤 2 中的图像 2,3 How to Fix a Loose Arm Rest for Office Chair 068-0935-6: 步骤 2 中的图像 3,3
    • Avoid scratching the chair with the bolts when removing them from the arm rest.
    • Do the same as mentioned in Step 1 to the other bolts.
  3. How to Fix a Loose Arm Rest for Office Chair 068-0935-6: 步骤 3 中的图像 1,3 How to Fix a Loose Arm Rest for Office Chair 068-0935-6: 步骤 3 中的图像 2,3 How to Fix a Loose Arm Rest for Office Chair 068-0935-6: 步骤 3 中的图像 3,3
    • After removing the arm rest, get a Q-tip and start cleaning the bolt holes.
    • Make sure to thoroughly clean the insides and use a new Q-tip for a new hole.
  4. How to Fix a Loose Arm Rest for Office Chair 068-0935-6: 步骤 4 中的图像 1,2 How to Fix a Loose Arm Rest for Office Chair 068-0935-6: 步骤 4 中的图像 2,2
    • Adjust the arm so that each hole is aligned with the hole where the bolt goes in as shown in the picture.
    • Get help from another person to hold the armrest up so it stays in alignment.
  5. How to Fix a Loose Arm Rest for Office Chair 068-0935-6: 步骤 5 中的图像 1,3 How to Fix a Loose Arm Rest for Office Chair 068-0935-6: 步骤 5 中的图像 2,3 How to Fix a Loose Arm Rest for Office Chair 068-0935-6: 步骤 5 中的图像 3,3
    • Reassemble the arm rest and place the the bolts back as they were.
    • To tighten the bolts, turn the hex key in a clockwise direction.
  6. How to Fix a Loose Arm Rest for Office Chair 068-0935-6: 步骤 6 中的图像 1,2 How to Fix a Loose Arm Rest for Office Chair 068-0935-6: 步骤 6 中的图像 2,2
    • Tighten the bolts and check to see if they are tight enough.
    • Check the arm rests to see if they are stiff and not wobbly
    • Check each bolt and tighten till the arm rest isn't wobbly.
  7. How to Fix a Loose Arm Rest for Office Chair 068-0935-6: 步骤 7 中的图像 1,3 How to Fix a Loose Arm Rest for Office Chair 068-0935-6: 步骤 7 中的图像 2,3 How to Fix a Loose Arm Rest for Office Chair 068-0935-6: 步骤 7 中的图像 3,3
    • Repeat Steps 1-6 for the other arm rest.
结论
Celince Kapadia
于06/30/21注册
145 声望
撰写一个指南
团队
2条评论
Suppose that the bolt is not hex or phillips or star, but is completely smooth and the fabric is closed with stitching. After removing the caps that cover the holes in the arm there is just a completely smooth bolt or screw with no way to grip or turn it?????
Ray Carpenter - 回复
At the very least say to put a lot of cotton on the hole so it will tighten the hole up when u put the screw in. And or put a washer on each bolt. What a joke.
adam - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 15
过去 30 天: 92
总计 3,370
