跳转到主内容
How to Fix a Leaning Wooden Gate
你所需要的
  1. How to Fix a Leaning Wooden Gate, How to Fix a Leaning Wooden Gate: 步骤 1 中的图像 1,2 How to Fix a Leaning Wooden Gate, How to Fix a Leaning Wooden Gate: 步骤 1 中的图像 2,2
    • Begin by measuring the gap under the gate to determine the exact height needed for correction.
  2. How to Fix a Leaning Wooden Gate: 步骤 2 中的图像 1,1
    • Choose any object that is the same size as the measured gap.
    • Place the selected object under the gate to ensure the gate is level and straight.
  3. How to Fix a Leaning Wooden Gate: 步骤 3 中的图像 1,3 How to Fix a Leaning Wooden Gate: 步骤 3 中的图像 2,3 How to Fix a Leaning Wooden Gate: 步骤 3 中的图像 3,3
    • Place the wheel on the side where the door is leaning down.
    • Mark the hole location for drilling.
    • Use masking tape only if the door is the same colour as your marking object.
  4. How to Fix a Leaning Wooden Gate: 步骤 4 中的图像 1,3 How to Fix a Leaning Wooden Gate: 步骤 4 中的图像 2,3 How to Fix a Leaning Wooden Gate: 步骤 4 中的图像 3,3
    • Drill holes on the marked circles.
    • Ensure your holes are the same size as the screw you are using.
  5. How to Fix a Leaning Wooden Gate: 步骤 5 中的图像 1,2 How to Fix a Leaning Wooden Gate: 步骤 5 中的图像 2,2
    • Attach the wheel and place the screws .
    • Depending on what the kit provides, use a wrench to tighten the bolts or a screwdriver to tighten the screws.
    • Ensure that the screw is tightened securely to prevent a loose wheel.
  6. How to Fix a Leaning Wooden Gate: 步骤 6 中的图像 1,2 How to Fix a Leaning Wooden Gate: 步骤 6 中的图像 2,2
    • Remove the object you placed underneath.
结论
Test out your newly added wheels, if it is wobbly make sure to tighten the wheels again.
TenzinY
于09/08/23注册
133 声望
撰写一个指南
团队
York University, Team 2-26, O'Regan Fall 2023 York University, Team 2-26, O'Regan Fall 2023 的会员
YORK-O'REGAN-F23S2G26
1 名成员
创作了1篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 17
总计 467
