跳转到主内容
How to Fix a Leaky Gutter
你所需要的
  1. How to Fix a Leaky Gutter, How to Fix a Leaky Gutter: 步骤 1 中的图像 1,3 How to Fix a Leaky Gutter, How to Fix a Leaky Gutter: 步骤 1 中的图像 2,3 How to Fix a Leaky Gutter, How to Fix a Leaky Gutter: 步骤 1 中的图像 3,3
    • Clean the area around the leak with a wire bush or garden trowel and a bucket, taking out the leaves and debris placing what you remove in the bucket and flushing the gutters with water using a hose to make sure you have a clean area, as well as rinsing and drying the area thoroughly.
    • Since this requires a ladder, it is better to have another adult nearby just to stay safe!
  2. How to Fix a Leaky Gutter: 步骤 2 中的图像 1,1
    • Apply plastic roofing cement to any holes present in the gutters by working it into the hole or crack with a putty knife or trowel.
  3. How to Fix a Leaky Gutter: 步骤 3 中的图像 1,1
    • Smooth out the cement by using the putty knife or trowel so that can smooth out any rough edges.
  4. How to Fix a Leaky Gutter: 步骤 4 中的图像 1,1
    • Remove any screws or connecting hardware at the joint of any leaking or worn portion of the downspout and then disassemble any leaking or worn portion of the downspout joint.
  5. How to Fix a Leaky Gutter: 步骤 5 中的图像 1,1
    • Clean any caulks from around the downspout joints using a stiff wire brush.
  6. How to Fix a Leaky Gutter: 步骤 6 中的图像 1,1
    • Apply the silicone caulk to the joint area to seal leaks and reassemble the gutter system.
结论
To reassemble the downsprout: screw back any screws or connecting hardware back into the downsprout.
3等其他人完成本指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 19
过去 30 天: 78
总计 2,960
