跳转到主内容
How to Fix a Leak on a Twisted Thermal Mug from Starbucks
你所需要的
  1. How to Fix a Leak on a Twisted Thermal Mug from Starbucks, Silicone Gasket: 步骤 1 中的图像 1,3 How to Fix a Leak on a Twisted Thermal Mug from Starbucks, Silicone Gasket: 步骤 1 中的图像 2,3 How to Fix a Leak on a Twisted Thermal Mug from Starbucks, Silicone Gasket: 步骤 1 中的图像 3,3
    • Fill the bottle with water and secure the lid.
    • Tilt, shake, or turn it upside down to pinpoint the source of the leak—whether it’s from the lid, spout, or base.
  2. How to Fix a Leak on a Twisted Thermal Mug from Starbucks: 步骤 2 中的图像 1,2 How to Fix a Leak on a Twisted Thermal Mug from Starbucks: 步骤 2 中的图像 2,2
    • Open the bottle and examine the rubber gasket or O-ring inside the lid.
    • Look for cracks, deformation, brittleness, or signs of wear.
  3. How to Fix a Leak on a Twisted Thermal Mug from Starbucks: 步骤 3 中的图像 1,2 How to Fix a Leak on a Twisted Thermal Mug from Starbucks: 步骤 3 中的图像 2,2
    • Take apart all removable components—cap, straw, inner seals.
    • Ensure everything is cleaned and inspected.
  4. How to Fix a Leak on a Twisted Thermal Mug from Starbucks: 步骤 4 中的图像 1,1
    • Measure the rubber part’s inner and outer diameter, and its thickness.
    • This helps in finding the correct replacement.
  5. How to Fix a Leak on a Twisted Thermal Mug from Starbucks: 步骤 5 中的图像 1,3 How to Fix a Leak on a Twisted Thermal Mug from Starbucks: 步骤 5 中的图像 2,3 How to Fix a Leak on a Twisted Thermal Mug from Starbucks: 步骤 5 中的图像 3,3
    • Carefully insert the new O-ring, ensuring it fits snugly into its groove.
    • Avoid overstretching or misaligning the new seal.
  6. How to Fix a Leak on a Twisted Thermal Mug from Starbucks: 步骤 6 中的图像 1,3 How to Fix a Leak on a Twisted Thermal Mug from Starbucks: 步骤 6 中的图像 2,3 How to Fix a Leak on a Twisted Thermal Mug from Starbucks: 步骤 6 中的图像 3,3
    • Wash all components with mild soap and warm water.
    • Use a soft brush or cotton swab to clean hard-to-reach areas.
    • Rinse and let everything dry completely.
  7. How to Fix a Leak on a Twisted Thermal Mug from Starbucks: 步骤 7 中的图像 1,1
    • Put the bottle back together and fill it again to test.
    • Shake or turn it upside down to confirm the seal is holding and the leak is gone.
结论
We hope this simple and practical guide helps people to give new life to their water bottles. This guide focuses on making this repair easy, accessible, and affordable with tools available at home. We believe that this repair is a great way to keep your bottle in use, and out of landfills for years to come. Thank you for reading our guide, happy fixing!
3等其他人完成本指南。
团队
UC Davis, Team 2-1, Whithaus Spring 2025 UC Davis, Team 2-1, Whithaus Spring 2025 的会员
UCD-WHITHAUS-S25S2G1
3 名成员
创作了1篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 42
总计 332
