跳转到主内容
How to Fix a Jammed Key on a Logitech K120
你所需要的
  1. How to Fix a Jammed Key on a Logitech K120, How to Fix a Jammed Key on a Logitech K120: 步骤 1 中的图像 1,2 How to Fix a Jammed Key on a Logitech K120, How to Fix a Jammed Key on a Logitech K120: 步骤 1 中的图像 2,2
    • Unplug the keyboard to prevent accidental damage.
  2. How to Fix a Jammed Key on a Logitech K120: 步骤 2 中的图像 1,3 How to Fix a Jammed Key on a Logitech K120: 步骤 2 中的图像 2,3 How to Fix a Jammed Key on a Logitech K120: 步骤 2 中的图像 3,3
    • Gently remove the keycap using a keycap puller/screwdriver/nylon spudger, or a plastic opening tool. Inspect for dirt, dust, or misalignment.
    • Avoid using excessive force to prevent damage.
  3. How to Fix a Jammed Key on a Logitech K120: 步骤 3 中的图像 1,1
    • Clean the area under the key using compressed air, a microfiber cloth, or a cotton swab for detailed cleaning.
  4. How to Fix a Jammed Key on a Logitech K120: 步骤 4 中的图像 1,3 How to Fix a Jammed Key on a Logitech K120: 步骤 4 中的图像 2,3 How to Fix a Jammed Key on a Logitech K120: 步骤 4 中的图像 3,3
    • Examine the stabilizer and ensure it is properly attached.
  5. How to Fix a Jammed Key on a Logitech K120: 步骤 5 中的图像 1,1
    • Test the switch by pressing it without the keycap (you can press it with a cotton swab).
  6. How to Fix a Jammed Key on a Logitech K120: 步骤 6 中的图像 1,2 How to Fix a Jammed Key on a Logitech K120: 步骤 6 中的图像 2,2
    • Reattach the keycap by aligning it properly and pressing it down firmly but gently to avoid damaging the switch.
  7. How to Fix a Jammed Key on a Logitech K120: 步骤 7 中的图像 1,2 How to Fix a Jammed Key on a Logitech K120: 步骤 7 中的图像 2,2
    • Test the key’s functionality by typing in a text editor or keyboard tester to ensure proper response. If the issue persists, repeat cleaning steps.
终点
另外一个人完成了本指南。
RepairWithAI
于01/25/25注册
145 声望
撰写一个指南
团队
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 12
过去 30 天: 32
总计 284
