跳转到主内容
How to Fix a Honda GCV160 Lawnmower With Water in the Fuel Line
你所需要的
  1. How to Fix a Honda GCV160 Lawnmower With Water in the Fuel Line, How to Fix a Honda GCV160 Lawnmower With Water in the Fuel Line: 步骤 1 中的图像 1,1
    • Move the dial to a vertical position to close the fuel line.
    • This will prevent fluids from continuing to move freely throughout the lawnmower.
  2. How to Fix a Honda GCV160 Lawnmower With Water in the Fuel Line: 步骤 2 中的图像 1,3 How to Fix a Honda GCV160 Lawnmower With Water in the Fuel Line: 步骤 2 中的图像 2,3 How to Fix a Honda GCV160 Lawnmower With Water in the Fuel Line: 步骤 2 中的图像 3,3
    • Use the screwdriver to push the right tension pin to the right so the hose can be removed.
    • Remove the right hose by wiggling the screwdriver between the hose and the tube where it is attached.
    • Have the empty bottle ready to use as soon as the hose is detached from the fuel line.
  3. How to Fix a Honda GCV160 Lawnmower With Water in the Fuel Line: 步骤 3 中的图像 1,1
    • Place the hose into a bottle to catch the leaking fluid from the fuel tank.
    • More liquid will be released from the right hose than in any other part of the process.
  4. How to Fix a Honda GCV160 Lawnmower With Water in the Fuel Line: 步骤 4 中的图像 1,3 How to Fix a Honda GCV160 Lawnmower With Water in the Fuel Line: 步骤 4 中的图像 2,3 How to Fix a Honda GCV160 Lawnmower With Water in the Fuel Line: 步骤 4 中的图像 3,3
    • Move the tension pin to the left to allow the hose to be removed.
    • Remove the left hose and catch the fluids that leak out.
  5. How to Fix a Honda GCV160 Lawnmower With Water in the Fuel Line: 步骤 5 中的图像 1,2 How to Fix a Honda GCV160 Lawnmower With Water in the Fuel Line: 步骤 5 中的图像 2,2
    • Remove the 10 mm bolt holding the carburetor fuel cup in place.
    • Remove the carburetor fuel cup
    • Use the rag to clean the inside of the carburetor fuel cup after it has been removed.
    • Let any fluid released from removing the carburetor spill onto the rag.
  6. How to Fix a Honda GCV160 Lawnmower With Water in the Fuel Line: 步骤 6 中的图像 1,1
    • Tilt the lawnmower forward so any remaining fluids can make their way out.
  7. How to Fix a Honda GCV160 Lawnmower With Water in the Fuel Line: 步骤 7 中的图像 1,1
    • Place the detached hoses back to the fuel line.
    • Move the pins back to the end of the hose to hold them in place.
  8. How to Fix a Honda GCV160 Lawnmower With Water in the Fuel Line: 步骤 8 中的图像 1,1
    • Use the fuel can to refill the lawnmower now that the contaminated fuel has been removed.
  9. How to Fix a Honda GCV160 Lawnmower With Water in the Fuel Line: 步骤 9 中的图像 1,1
    • Turn the dial to a horizontal position to reopen the fuel line.
结论
With the water out of the fuel line, the lawnmower should be ready for use.
2等其他人完成本指南。
Alonso Pantoja
于01/24/22注册
223 声望
撰写一个指南
团队
CSU Los Angeles, Team 6-10, Briggs Spring 2022 CSU Los Angeles, Team 6-10, Briggs Spring 2022 的会员
CSULA-BRIGGS-S22S6G10
1 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 21
过去 30 天: 106
总计 1,552
