跳转到主内容
How to Fix a Hole in a Pant Pocket
你所需要的
  1. How to Fix a Hole in a Pant Pocket, How to Fix a Hole in a Pant Pocket: 步骤 1 中的图像 1,2 How to Fix a Hole in a Pant Pocket, How to Fix a Hole in a Pant Pocket: 步骤 1 中的图像 2,2
    • Flip the pocket inside out.
  2. How to Fix a Hole in a Pant Pocket: 步骤 2 中的图像 1,2 How to Fix a Hole in a Pant Pocket: 步骤 2 中的图像 2,2
    • Carefully align the ripped part of the pocket together.
  3. How to Fix a Hole in a Pant Pocket: 步骤 3 中的图像 1,3 How to Fix a Hole in a Pant Pocket: 步骤 3 中的图像 2,3 How to Fix a Hole in a Pant Pocket: 步骤 3 中的图像 3,3
    • Put a sewing pin into a stable piece of fabric to make a hole.
    • Carefully remove the pins.
  4. How to Fix a Hole in a Pant Pocket: 步骤 5 中的图像 1,3 How to Fix a Hole in a Pant Pocket: 步骤 5 中的图像 2,3 How to Fix a Hole in a Pant Pocket: 步骤 5 中的图像 3,3
    • Carefully insert the a threaded sewing needle into the hole you created at one end of the tear.
    • Sew along the length of the tear, joining the two pieces of fabric together.
    • Be very careful when using needle as the point can be very sharp and lead to injury.
  5. How to Fix a Hole in a Pant Pocket: 步骤 6 中的图像 1,2 How to Fix a Hole in a Pant Pocket: 步骤 6 中的图像 2,2
    • Sew around the ending part a couple times to prevent it from loosen again.
  6. How to Fix a Hole in a Pant Pocket: 步骤 7 中的图像 1,1
    • Tie a few knots on both ends of the closed tear to ensure the stitching doesn't come loose.
    • Carefully cut the remaining thread.
    • Be very careful while cutting the thread to avoid cutting some part of the material also.
结论
Dolapo Ajose
于09/20/21注册
220 声望
撰写一个指南
团队
York University, Team F-7, Woodhouse Fall 2021 York University, Team F-7, Woodhouse Fall 2021 的会员
YORK-WOODHOUSE-F21SFG7
1 名成员
创作了1篇指南
一条评论
I found a good reference video for this guide: https://youtube.com/watch?v=LJ5y4mLVbY0
5moufl - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 18
过去 30 天: 91
总计 3,980
