跳转到主内容
How to Fix a Hole in Leggings by Hand Sewing
你所需要的
  1. How to Fix a Hole in Leggings by Hand Sewing, How to Fix a Hole in Leggings by Hand Sewing: 步骤 1 中的图像 1,3 How to Fix a Hole in Leggings by Hand Sewing, How to Fix a Hole in Leggings by Hand Sewing: 步骤 1 中的图像 2,3 How to Fix a Hole in Leggings by Hand Sewing, How to Fix a Hole in Leggings by Hand Sewing: 步骤 1 中的图像 3,3
    • Use scissors to cut a piece of thread that is the color of your leggings at least 12 inches long.
  2. How to Fix a Hole in Leggings by Hand Sewing: 步骤 2 中的图像 1,1
    • Mishandling of the needle could result in minor or moderate injury.
    • Thread the needle by running the piece of thread through the eye, or opening, of the needle.
  3. How to Fix a Hole in Leggings by Hand Sewing: 步骤 3 中的图像 1,1
    • Pull the thread through the needle until there are two equal halves of thread.
    • Tie a knot with the ends of the thread.
  4. How to Fix a Hole in Leggings by Hand Sewing: 步骤 4 中的图像 1,1
    • Turn the leggings inside out.
    • This is so the sewing will be on the inside of the leggings.
  5. How to Fix a Hole in Leggings by Hand Sewing: 步骤 5 中的图像 1,1
    • Smooth out the fabric around the hole.
  6. How to Fix a Hole in Leggings by Hand Sewing: 步骤 6 中的图像 1,1
    • Pinch the fabric together.
    • Begin your stitch on one end of the hole.
  7. How to Fix a Hole in Leggings by Hand Sewing: 步骤 7 中的图像 1,1
    • Use short stitches so that the thread will not break easily.
    • Make sure the hole is completely included in the stitches.
  8. How to Fix a Hole in Leggings by Hand Sewing: 步骤 8 中的图像 1,1
    • Tie a knot using the tied ends of the thread (at the beginning of the hole) and the thread still attached to the needle (at the end of the hole).
    • Make sure the knot is large enough so it doesn't slip through the stitches.
  9. How to Fix a Hole in Leggings by Hand Sewing: 步骤 9 中的图像 1,1
    • Cut the loose thread above the new knot with scissors.
终点
2等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 30
过去 7 天: 233
过去 30 天: 1,134
总计 40,846
