跳转到主内容
How to Fix a Hole In Wall
你所需要的
  1. How to Fix a Hole In Wall, Dry wall: 步骤 1 中的图像 1,3 How to Fix a Hole In Wall, Dry wall: 步骤 1 中的图像 2,3 How to Fix a Hole In Wall, Dry wall: 步骤 1 中的图像 3,3
    在这个步骤中使用的工具:
    • Use pliers (or tweezers if the hole is very small) to clean out hole by removing the drywall out of the hole.
  2. How to Fix a Hole In Wall: 步骤 2 中的图像 1,1
    • Use scissors to cut drywall mesh.
    • To ensure that the entire hole is covered, cut a piece of mesh larger than the size of the hole.
  3. How to Fix a Hole In Wall: 步骤 3 中的图像 1,2 How to Fix a Hole In Wall: 步骤 3 中的图像 2,2
    • Use a damp sponge to apply moisture to make the mesh stick to the wall, covering the entire hole.
  4. How to Fix a Hole In Wall: 步骤 4 中的图像 1,3 How to Fix a Hole In Wall: 步骤 4 中的图像 2,3 How to Fix a Hole In Wall: 步骤 4 中的图像 3,3
    • Use a drywall knife to apply the drywall compound over the mesh. Make sure to spread a generous amount over the entire mesh.
    • Let the compound dry for about 30 minutes.
    • You can speed up the drying process by placing a fan directly in front of the drying compound.
  5. How to Fix a Hole In Wall: 步骤 5 中的图像 1,1
    • Once compound is dry, use sandpaper to smooth out the entire surface of the dried compound.
  6. How to Fix a Hole In Wall: 步骤 6 中的图像 1,3 How to Fix a Hole In Wall: 步骤 6 中的图像 2,3 How to Fix a Hole In Wall: 步骤 6 中的图像 3,3
    • Paint over the surface with a paint brush.
    • Use paint that matches the rest of the wall for best results.
结论
7等其他人完成本指南。
1指南评论
Oi! como faço reboca que a parede está pintada branca?
dezinho anderson - 回复
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 29
过去 30 天: 155
总计 8,214
