跳转到主内容
How to Fix a Flexi Leash
你所需要的
视频概述
  1. How to Fix a Flexi Leash, How to Fix a Flexi Leash: 步骤 1 中的图像 1,1
    • Place the object in a clear bright space.
  2. How to Fix a Flexi Leash: 步骤 2 中的图像 1,3 How to Fix a Flexi Leash: 步骤 2 中的图像 2,3 How to Fix a Flexi Leash: 步骤 2 中的图像 3,3
    • Start by removing all the 0.5 cm screws off the leash with the Phillips #0 screwdriver.
  3. How to Fix a Flexi Leash: 步骤 3 中的图像 1,3 How to Fix a Flexi Leash: 步骤 3 中的图像 2,3 How to Fix a Flexi Leash: 步骤 3 中的图像 3,3
    • Using a plastic opening tool, begin to separate the top and bottom of the leash.
    • Make sure to press lightly to prevent unwanted marks.
    • It is most likely that the brake button will fall out. Place small items to the side to prevent it from being lost or undetected.
  4. How to Fix a Flexi Leash: 步骤 4 中的图像 1,2 How to Fix a Flexi Leash: 步骤 4 中的图像 2,2
    • Carefully remove the brake mechanism. Inside should be a small spring.
    • Remove and replace the spring with a new one.
    • When placing the break mechanism back into its place, make sure the spring is positioned right in the middle.
  5. How to Fix a Flexi Leash: 步骤 5 中的图像 1,3 How to Fix a Flexi Leash: 步骤 5 中的图像 2,3 How to Fix a Flexi Leash: 步骤 5 中的图像 3,3
    • When the spring is successfully placed, initiate the retraction to it's original position.
    • Make sure the top and the bottom are aligned properly.
    • Slowly press the top and the bottom of the leash until it returns to its initial position.
  6. How to Fix a Flexi Leash: 步骤 6 中的图像 1,3 How to Fix a Flexi Leash: 步骤 6 中的图像 2,3 How to Fix a Flexi Leash: 步骤 6 中的图像 3,3
    • Finish by screwing the 0.5 cm screws in their original position.
终点
一条评论
Where do i buy the spring?
Andrew Storeck - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 17
过去 30 天: 102
总计 4,226
