跳转到主内容
How to Fix a Feather Cat Toy
你所需要的
  1. How to Fix a Feather Cat Toy, How to Fix a Feather Cat Toy: 步骤 1 中的图像 1,2 How to Fix a Feather Cat Toy, How to Fix a Feather Cat Toy: 步骤 1 中的图像 2,2
    • Slide a crimp onto the cat toy's line.
    • Thread the line through the ring of the key clasp.
    • You should have a small loop formed at the end of the line.
  2. How to Fix a Feather Cat Toy: 步骤 2 中的图像 1,2 How to Fix a Feather Cat Toy: 步骤 2 中的图像 2,2
    • Slide the crimp down to close the loop. Make sure that the crimp covers each part of the line.
    • Use your crimping tool or pliers in order to secure the crimp.
  3. How to Fix a Feather Cat Toy: 步骤 3 中的图像 1,1
    • Apply super glue to any cracks visible on the feather capsule for maximum security.
    • Let the feather capsule piece dry entirely before proceeding to the next step.
  4. How to Fix a Feather Cat Toy: 步骤 4 中的图像 1,1
    • Use regular glue to fill the inner portion of the feather capsule.
    • Fill it up only halfway in order to leave enough space for feathers.
  5. How to Fix a Feather Cat Toy: 步骤 5 中的图像 1,2 How to Fix a Feather Cat Toy: 步骤 5 中的图像 2,2
    • Individually insert the quill of each feather into the capsule.
    • Work quickly so that the glue doesn’t dry and cause the feathers to stick in the wrong direction.
  6. How to Fix a Feather Cat Toy: 步骤 6 中的图像 1,1
    • Press down on the clasp lever to open up the hinge.
    • Slide the loop on the feather connector into the clasp to reconnect the toy.
结论
Repeat the instructions in this guide every time your cat breaks their toy!
另外一个人完成了本指南。
Isabella Markell
于04/24/24注册
148 声望
撰写一个指南
团队
UC Davis, Team 1-6, Whithaus Spring 2024 UC Davis, Team 1-6, Whithaus Spring 2024 的会员
UCD-WHITHAUS-S24S1G6
3 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 25
总计 50
